Car shakes while braking
Old Sep 15, 2007 | 12:46 AM
YupImJOee's Avatar
YupImJOee
Default Car shakes while braking
When im driving and go for the brakes the car seems to shake. it shakes like the rotors are uneven or something. Im guessing the motor mounts are gone because when i rev the engine moves a lot and when i brake my shifter also moves. anyone else had this problem? how'd they fix it?
Old Sep 15, 2007 | 12:50 AM
Lexus Boy's Avatar
Lexus Boy
rotors prolly need to be replaced mine dose it too i plan on replacing them
Old Sep 15, 2007 | 12:51 AM
tommyjaix's Avatar
tommyjaix
I have the same problem here with a 2001 gs300. anyone know something about this?
Old Sep 15, 2007 | 10:17 AM
V300Graham's Avatar
V300Graham
It can also be worn steering link arms,
the linkages that connect the steering rack,
to the axles...
I just replaced both of mine,
and it totally fixed my
wobbling under braking issues.
Old Sep 15, 2007 | 01:42 PM
habdelr's Avatar
habdelr
Unhappy
I just got back from the brake shop with the same issue. They said my rotors needed replacing, so did my pads. Basically I had a complete brake job done to get rid of this problem. Now it still shakes a little but that's because my lower ball joints need to be replaced as well.
I basically drove the car too long while it was shaking that it messed up my lower ball joints. Lesson learned
Old Sep 15, 2007 | 02:20 PM
Seize's Avatar
Seize
Loves Snickerdoodles!
to the axles...
Ah, that's some good info right there. I'll have to check mine, cause I know for sure it isn't my brakes/rotors casuing the shaking either.
Old Sep 15, 2007 | 09:31 PM
2JZ147's Avatar
2JZ147
Default Rotors
If the rotors aren't too old, you can get away with just machining the rotors ONLY. That would solve your pulsation issue. Make sure you lubricate the caliper sliders as well and clean the mating surface on the rotor itself and the hub assembly.
Old Sep 16, 2007 | 09:31 AM
YupImJOee's Avatar
YupImJOee
wait are OEM rotors slotted/drilled? mine are..
Old Sep 19, 2007 | 02:07 PM
THINKtank's Avatar
THINKtank
just resurface the rotor i think you'll be fine
Old Sep 19, 2007 | 02:46 PM
A.R.'s Avatar
A.R.
My left front lower ball joint needs to be replaced now, and my rotors are crystallized...no machining for them, new ones are coming!
Old Sep 19, 2007 | 02:58 PM
josephdoc's Avatar
josephdoc
Only when applying brake huh!?!
Take it to a reputable repair store and get a free brake inspection. Usually just need to turn rotors if rotors are above its thickness requirement. If brakes are in good condtion, you might have a problem with your vehicle's front end linkage... then you will need a a good alignment tech's inspection.
Old Sep 19, 2007 | 03:32 PM
A.R.'s Avatar
A.R.
Where would be the best place to get the lower ball joints from? I thought it was my rotors (I have the same problem) but when you cut the wheel hard to turn around it'll shake also.
My brakes squealed until I got the pads changed today, but my rotors are still crystallized. so I have some maintenance to catch up on before i can do my mods
Old Sep 19, 2007 | 05:17 PM
Kaiser's Avatar
Kaiser
Cheapest I could find.
http://www.toyolexparts.com/web/inde...Path=17_48_107
Old Sep 19, 2007 | 05:52 PM
A.R.'s Avatar
A.R.
Thanks a million man. really appreciate it!
ThumperPup
Apr 17, 2018 01:26 PM
vonhayek
Jul 26, 2014 05:40 AM
swimdad92
Aug 13, 2011 03:05 PM
llllee4
Suspension and Brakes
Sep 30, 2009 07:46 PM
jtgs400
Mar 17, 2005 04:09 PM
