broken spark plug
Old Aug 7, 2006 | 06:02 AM
MIC123321's Avatar
MIC123321
Default broken spark plug
Well, here's the deal, i was changing my spark plugs 2 days ago and one decide to break flush to the block. Without taking the head off, is there another way to take that piece of the spark plug out?
Old Aug 7, 2006 | 12:55 PM
plkyone's Avatar
plkyone
If it is just the thread thats left in there and the center is hollow u can maybe use a bolt extractor they may have some at your loacal auto parts. Let me know how or where exactly it broke.
Old Aug 7, 2006 | 01:18 PM
Tammy's Avatar
Tammy
But did any pieces of the plug insulator fall into the combustion chamber?
Will there be any metal shavings from using an easy-out?
You may have to remove the head to be sure ...
The torque spec is 14-18 Ft Lbs for the spark plugs.
Old Aug 7, 2006 | 03:13 PM
MIC123321's Avatar
MIC123321
yeah just the thread is left in the block and i have to wait for my dad to bring me my drills so i could just drill it out. i talked to some shops here and they told me to use a magnet or shop vac to get the shavings out and maybe compressed air.
Old Aug 7, 2006 | 05:40 PM
007's Avatar
007
You can also use a "left hand drill bit" Its does the same thing as an eas out or bolt extractor, but its easier. It will spin the plug counterclockwise.
Old Aug 7, 2006 | 06:55 PM
gs300pnp's Avatar
gs300pnp
Registered User
seems like your plug may have seized. Take great care not to mess up the threads.
Good luck.
Old Aug 7, 2006 | 07:17 PM
MIC123321's Avatar
MIC123321
yeah, the spark plug is seized and hopefully i don't screw up the thread, but i guess i could re thread it? Another thing i found out was that the covers for the cam shafts weren't even bolted down, i could unscrew the bolts with my hand and it been shooting oil out for who knows how long? i was wondering why it keep on getting dirty every time i clean the engine bay.
Old Aug 8, 2006 | 07:08 AM
007's Avatar
007
The bolts loosening over time is a common problem according to my dealer. But it has not been talked about here on CL. I noticed it one day while I was doing about 130mph and all of a sudden I saw smoke and oil on my windshield. I thought I blew up the motor. When I got the car home. Called a friend of mine who is a mechanic at Lexus he told me to check the valve cover bolts. When I did, they were loose. I tightened them, cleaned the engine and the problem was gone. Whew!
Old Aug 8, 2006 | 07:30 AM
MIC123321's Avatar
MIC123321
yeah, i think thats why i been filling up a half a quart or more of oil in between oil changes.
Old Aug 8, 2006 | 07:32 AM
plkyone's Avatar
plkyone
You can use a little Blue loctite on the valve covel bolts that will help keep em in
Old Aug 8, 2006 | 09:06 AM
MIC123321's Avatar
MIC123321
yeah, i will be doing theses things tomorrow and helpfully it works out so i don't have to take it to the shop, cause school doesn't starts in till 3 weeks and i don't have all my tools to work on my ride.
Old Aug 8, 2006 | 09:45 AM
nyARISTO's Avatar
nyARISTO
Sunroof Surfer
all i can say is good luck i hope nothing but good things for you...this is a first for me to hear
Old Aug 9, 2006 | 09:14 PM
MIC123321's Avatar
MIC123321
yeah, the part of the spark plug is not moving at all, i broke one of the extractors, I finally got a hold of my advisor and he's letting me bring my ride into the shop a couple of weeks early so i could get it running. i'm guessing i going to be taking the head and where do i start?
cheerio3
RX - 1st Gen (1999-2003)
Feb 8, 2015 11:21 AM
sam430
Apr 28, 2011 09:48 PM
94SC4
May 24, 2008 09:17 PM
pimplux808
Performance
Nov 1, 2007 09:45 PM
Hermosa
Oct 18, 2001 03:58 AM
