Alternator problem
Nope. the break lights drain lots of lower. we have 8 dual filament bulbs going on at the same time and the rear deck LED break lights. I had the exact same problem right before the alternator died on me. Everytime i stepped on the breaks my rpm needle and speedometer needle all the lights inside would cut off. and my engine would die if i held on any longer. but as soon as i let go it was fine..... I had to drive the last mile home using the emergency break that way the engine wouldn't die.
Sorry J, I should have quoted... my response was in reply to Xeeeee***s post / question.
One thing on the older 1UZ design that I'm not sure is an issue here as well, but the position of the alternator is under an area that sometimes gets a minor leak above it (power steering) that goes into the alternator causing issue.
My alternator is doing the same thing. If I hit the brakes with the A/C fan on, it slows it almost to a stop until I release the brake. It picks back up almost immediatly after releasing it. If I'm sitting at a light for too long the A/C will disenagage the stator and hot air starts to blow. Not good when it's 112 outside.
great... my alternator went out today luckily just my battery light came on..and i was in front of my house ready to leave.. to check the alternator i left the car running and took off one of the terminals and it cut off on me i dont know if i want to go OEM again because i think its at 60amps correct me if im wrong and with my TV and my 2 big amps..and a 4 gauge wire i need a little more juice i had this one rebuilt last summer... kaiser hows that supra alternator going on? if the plug and bolts go in easy i wouldnt mind buying one of those...
Originally Posted by Xeeeeeem
No lights for me yet! Does the light mean your alternator is dead or just low voltage?
come to find out i have an oil leak... its not the distributor o-ring its something below that but reguardless it murdered my alternator im riding on a 800 crank battery...
gsean400
Feb 23, 2015 11:06 AM
skottydznt
Jan 11, 2015 06:43 PM
