GS Problems? HELP
Old Jul 6, 2006 | 11:51 AM
20lexgs20's Avatar
20lexgs20
Exclamation GS Problems? HELP
Iv had my 93 GS300 for just over a year, and all of a sudden I notice that when I go from park to any gear the car begins to shake and if I’m not quick to either gas it or put it in neutral the car dies Once I get the car going it runs fine shifting through all the gears, untill I come to a stop, in gear, once again the car wants to die, unless I break and gas to keep it from dying. Does anybody have any clue as to why this is happening now. Please Help!!
Old Jul 6, 2006 | 12:12 PM
nyARISTO's Avatar
nyARISTO
Sunroof Surfer
TUNE UP!!!!! ........ spark plugs and wires will do and maybe change that egr valve too
Old Jul 6, 2006 | 01:12 PM
ARISTOh's Avatar
ARISTOh
Def. that EGR will help i had the same problem but only when i did a quick shift from Neutral to Drive (at a light) it would idle down then pick up speed on its own like nyARISTO said... tune up and change the EGR...
Old Jul 8, 2006 | 09:14 PM
20lexgs20's Avatar
20lexgs20
Well I don’t think it's the EGR, because that is used when the car is in neutral also.. and when I have it in neutral the car revs normal and runs fine. Do you think it could possibly be something with the transmission? Thanks for the responses.
Old Jul 8, 2006 | 09:41 PM
link13's Avatar
link13
Did you, by chance, happen to hose down the engine? Water likes to hang out in the spark plug holes and can cause these symptoms.
Old Jul 8, 2006 | 11:41 PM
20lexgs20's Avatar
20lexgs20
I made that mistake like 6 months ago. I got all that cleared out and the car ran fine after that. Like I said it runs fine when you start it and just let it sit there. It's untill you try to put it into gear when i start havin my problems. What happens is <>
1. Start car. let it warm up. (running fine)
2. Put it into gear reverse or drive and then the car starts hesitating then bam.. dies. ( like I don't know how to drive a clutch!)
The only way I can drive the car is if I'm on a hill where I can get rolling as soon as I put it into gear.
Old Jul 9, 2006 | 06:13 AM
cjones2402's Avatar
cjones2402
ummm might be your MAF.....had a 93 ES 300..did the same thing...until i changed my MAF..ran great after that
Old Jul 9, 2006 | 05:20 PM
turbogs300's Avatar
turbogs300
Definitely check cap, rotor, wires and plugs.
Old Jul 10, 2006 | 03:04 PM
20lexgs20's Avatar
20lexgs20
I was thinking it was going to be something with the transmission. I'll check the things that are listed, but if none of those are it.. I'll be back
Again thanks for the help.
Old Jul 11, 2006 | 07:14 AM
nyARISTO's Avatar
nyARISTO
Sunroof Surfer
dont think its that tranny .... making it stall like that prob MAF sensor or something else vacume leak .... something but not the tranny
Old Jul 14, 2006 | 06:53 PM
gompka's Avatar
gompka
check out the maf.. when mine was messed up the car used to like to die at low revs.
Old Jul 14, 2006 | 06:59 PM
Kaiser's Avatar
Kaiser
Oxygen sensor is my bet. I have like 4 extra ones. I am almost a damn scrap yard. If you are good with electronics and own a multimeter, find the pin for the O2. Turn the multimeter to millivolts. Start the car. The number should jump rapidly back and forth past 450 mv. 450 is stoich and what the ecu's goal is. If it's slow or doesn't move, it's shot. BTW if it reads over 450 it's richer and lower than it's lean. it should never go above 900mv or below 100mv really.
I can get you the pin from the shop manual tomorrow.
Old Jul 16, 2006 | 01:08 AM
007's Avatar
007
I had the same problem once. Ironically, it was the brake booster which is located behind the master cylinder. When you are shifting into gear you are pressing the brake and when you stop you are pressing the brake. When you take off your foot is off the brake. The booster is going bad and the car's computer doesn't know how to compensate for the change in pressure other than to cut off.
JAndersson
25
Jul 3, 2020 02:55 PM
jwynn
May 29, 2015 08:53 PM
LexChamp
Aug 5, 2007 04:56 PM
BrokenPath
Jan 13, 2007 06:25 AM
AUGuy21
May 31, 2006 05:56 AM
