factory amp help!!!please
Old Jun 11, 2006 | 10:20 PM
jdmARIST0's Avatar
jdmARIST0
Default factory amp help!!!please
hello there new to ownin a gen 1 gs300 n my factory amp is blown is there anyway were i could get a aftermaket amp n use the after market to power my inside speakers n head unit since the whole system went out???
Old Jun 12, 2006 | 06:55 AM
Kaiser's Avatar
Kaiser
I've got a spare in my garage. PM me if you want it.
Old Jun 12, 2006 | 04:18 PM
Flip4431's Avatar
Flip4431
yea i got one sittin in the trunk if you need it pm me
Old Jun 14, 2006 | 09:16 AM
gompka's Avatar
gompka
you can use an aftermarket amp, I have the wiring diagram around somewhere I could tell you which wires you need to tap into. I'm using an aftermarket amp with the stock radio in the car right now and it works well.
Old Jun 14, 2006 | 07:20 PM
Caius's Avatar
Caius
I wouldn't mind a peek at that wiring diagram for the aftermarket amp myself......
Old Jun 14, 2006 | 07:24 PM
Abear's Avatar
Abear
CL Folding 200,000
What are you doing to your car? You had a killer system in there.
Old Jun 14, 2006 | 08:45 PM
gompka's Avatar
gompka
car is 100% stock minus the suspension cause thats staying. The system is going with me to my new car. Most likely a scion tc
Old Jun 15, 2006 | 08:03 PM
jdmARIST0's Avatar
jdmARIST0
hey there were can i find the write up on how to connect the wires or can u gimme a write up on it???
Old Jun 15, 2006 | 10:18 PM
gompka's Avatar
gompka
you guys need to use the SEARCH function. I typed in wiring diagram and about 5 topics down i found this link. WIRING
However it is a bit tricky to understand at first. So if you want to hook up an aftermarket amp follow these instructions.
On your aftermarket amp you will have a remote connection which corresponds to the lexus acc connection. On the diagram the acc connection on the (stereo component amplifier) is marked 2B. Now B corresponds to plug S14. Go to the plugs page and look at plug S14 and find pin 2. This is the pin you need to use for your remote on the aftermarket amp.
Now the rca wires are the FRR+ (front right positive), FRR- (front right negative), FRL+ (front left positive), FRL- (front left negative), RRL-, RRL+, RRR-, RRR+ So when you wire up your rca connections the + wires goes to the prong and the - wire goes to the outside of the rca plug. Its actually really easy and a trained monkey can do it. Have fun
Old Jun 16, 2006 | 08:35 AM
Caius's Avatar
Caius
Oh, schnapp....I thought you meant you had one like on your computer....I'll search, of course it's not a big priority for me right now, not driveable and all....lol
joeker
Dec 29, 2025 09:11 AM
Lveyolfe
May 23, 2023 07:00 PM
ArmyofOne
Apr 26, 2019 04:41 AM
Arkansas
Sep 16, 2013 07:38 PM
vinh
Mar 15, 2005 03:03 PM
