excessive smoke
Old Mar 12, 2005 | 12:59 PM
vsd's Avatar
vsd
Default excessive smoke
at random times my car seems to have excessive ammounts of smoke coming out of the exhaust. when this happens the car is already warmed up, and i live in san diego so the weather is not cold. does anyone know why this is happening and what i can do to fix it?
Old Mar 12, 2005 | 02:08 PM
LexTE's Avatar
LexTE
What color is the smoke?
Old Mar 12, 2005 | 03:24 PM
turbogs300's Avatar
turbogs300
Cool
More than likely it's just moisture burning off the inside of the pipes as they heat up
Old Mar 12, 2005 | 08:15 PM
vsd's Avatar
vsd
the smoke is white/gray, but it always shows up at the most random times. and it leaves a black soot all over the back of my car so i dont think its moisture.
Old Mar 12, 2005 | 09:32 PM
ArmyofOne's Avatar
ArmyofOne
Dysfunctional Veteran
Veteran: Army
notice a decrease in engien power/smoothness? have a compression test done, it may be piston ring time. (which means you have to remove the heads, so you might as well do the head gaskets, and the rod bearings and the valve seals...and the, and the, and the....)
hate to be the bearer of bad news.
but do a compression test first, just to be sure.
turbogs300's Avatar
turbogs300
Cool
Does it use any oil?
Old Mar 12, 2005 | 09:36 PM
vsd's Avatar
vsd
theres no loss in smoothness or power, and it doesn't seem to burn any oil, but i'll see what i can do about getting a compression test
Old Mar 12, 2005 | 10:28 PM
turbogs300's Avatar
turbogs300
If it's not burning oil then more than likely your fine and it's what I said it is. My car does the same thing and it's fine. A compression test will tell ya.
Old Mar 12, 2005 | 10:52 PM
vsd's Avatar
vsd
thanks
bondavi
Jan 17, 2013 12:26 AM
Yambeezy
May 4, 2012 08:47 PM
BrownGuy
Oct 8, 2010 02:41 PM
Sirius2ten
18
Feb 7, 2008 12:51 PM
