power windows problem
Old Apr 28, 2004 | 06:01 PM
forksports's Avatar
forksports
Default power windows problem
Hi,
I recently purchased an 93 GS300, the passenger rear window will not roll up, but it will roll down if I was using the switch that is on the door. But from the driver master switch it doesn't roll up or down. What could be the problem? Is there a fuse for it? any help would be appreciate it, cause I live in OR and it's going to rain soon
thank you!
Old Apr 28, 2004 | 06:08 PM
SC400-V8's Avatar
SC400-V8
Im having a similar problem right now (new switch ordered from a clublexus member, you guys are FAST!!) Anyway, is the switch itself not lifting up to allow the window to roll up? That is the situation with mine, I believe the spring in it was displaced and got caught, jamming it so i couldnt lift the switch up enough to depress the window retract button. This happens every now and then.
No matter... go to classifieds and for about $50 you should be able to get a used but working switch assembly.
Old Apr 28, 2004 | 07:46 PM
forksports's Avatar
forksports
well I don't think is the switch now, because I tried the switch from my front passenger to the rear passenger and it still won't work. The rear driver window won't go up/down with the switch on the door but it'll go up/down no problem with the master switch on the driver side.
Old Apr 29, 2004 | 09:09 AM
Pianoman72's Avatar
Pianoman72
You don't have the window lock button on do you? lol, j/k. Pm me your email address - I got some info that will help you.
Old Aug 24, 2007 | 06:46 PM
jshooter55's Avatar
jshooter55
did anyone figure out the problem for the r/r window switch
05ls430518
Feb 26, 2018 08:40 AM
KiNGD206
Jan 10, 2014 07:13 PM
dadewi
Sep 18, 2012 09:16 AM
super58177
Aug 25, 2008 04:01 PM
SC4Hundred
Sep 19, 2006 01:03 PM
