instructions please
Old Nov 17, 2003 | 12:00 AM
  #31
indypwr's Avatar
indypwr
Post
here's another angle....
  #32
Wald GS's Avatar
Wald GS
O.C. Lucky Strike Fanatic
I'm going to resume installation tomorrow. I can't get the fat blue rubber band like thingy to fit on both the pipe and maf.. I need a bigger one..
Old Nov 17, 2003 | 12:02 AM
  #33
indypwr's Avatar
indypwr
Talking
do you like this?...................h.eh.ehe
Old Nov 17, 2003 | 12:54 AM
  #34
LB Lex's Avatar
LB Lex
Originally posted by LexAristo
What exactly is the purpose of a breather?
It takes air out of the cam-covers and puts it into the intake so it gets used in the combustion process.
Am I able to paint the rubber connector with high temp paint ?
I think it might crack or peel-off after a while. Performance auto-shops sell these connectors in many colors, so you can buy one that has the color you desire.
Btw guys, should I paint the intake pipe gunmetal, gray, blue or what? Thanks
I painted mine black so the engine looks stock. If you want to paint it blue or some other bright color, you should probably paint other parts of the engine compartment so it matches and looks nice.
Indypwr- he bro, haven't heard rom you in a while, how are you doing? We've missed you over here
Old Nov 17, 2003 | 01:13 AM
  #35
Wald GS's Avatar
Wald GS
does using a breather use up more gas? That's what I heard.. thanks Eric!
Old Nov 17, 2003 | 01:21 AM
  #36
LB Lex's Avatar
LB Lex
Sorry, I made a mistake when describing the purpose of the breather It doesn't suck air out of the cam-covers, air is sucked into the cam-covers from the intake. Cars today don't use a breather, instead they use a rubber tube to connect it to the intake so the air that is sucked into the cam-covers is accounted for by the MAF. That's why we have that rubber tube running from the cam-covers to the intake.
Okay, now to your question. I think it's a good possibility it would use more gas because if you use a breather, air is being sucked into the engine but it was not measured at the MAF. Therefore the engine will not have an accurate reading of how much air is going into the engine, so this can mess up the air/fuel ratio and your mileage might go down.
Old Nov 17, 2003 | 03:48 PM
  #37
Wald GS's Avatar
Wald GS
Intake is complete. Check out the new thread.
soulific
Aug 26, 2011 08:44 PM
niebla
Performance
May 26, 2010 12:01 PM
javyLSU
Performance
61
Dec 5, 2007 10:48 AM
