ES - 7th to 8th Gen (2019-present) Discussion topics related to 2019-present ES models
2021 Lexus es 350 USB hub
Old Mar 23, 2026 | 03:28 PM
unsuperman's Avatar
unsuperman
6th Gear
Default 2021 Lexus es 350 USB hub
Hello there. I have a 21 es 350, I was wondering how hard the front usb hub is to replace. It seems like any little bump and if I move my phone it disconnects from the car and stops charging. What all would I need to remove to be able to replace it? Or should I take it to the dealer?
Old Mar 24, 2026 | 12:19 AM
ESh's Avatar
ESh
You need to remove the following:
1. Shift ****
2. Knee pads
3. Mark Levinson plastic
4. Pull up the center console starting around the square cup holder
5. Disconnect the wires
Remove the USB hub by unscrewing to Philips screws.
Old Mar 24, 2026 | 06:07 AM
alextv's Avatar
alextv
Clean the contacts first to see if fixes problem.
Old Mar 24, 2026 | 06:24 AM
unsuperman's Avatar
unsuperman
6th Gear
I did clean them with some alcohol and a brush and it didn't help much unfortunately
Old Mar 24, 2026 | 06:45 AM
F3Woody's Avatar
F3Woody
Sorry to be 'that guy', but have you tried a different charging cable? My guess would be the problem lies in the cable connection rather than inside the port, and I'd hate to see you go for the difficult fix before trying the easy ones.
Old Mar 24, 2026 | 07:13 AM
unsuperman's Avatar
unsuperman
6th Gear
Yes I have, no worries being that guy 😅 . It does the same thing with usb c and an iPhone cable as well. So I know it's something with the actual hub and not the cables
Old Mar 24, 2026 | 10:01 AM
alextv's Avatar
alextv
Maybe take a straight pin and see if can bend prongs back in shape. Before that use small piece of emery cloth to clean and or use contact cleaner first as that removes the residue better than alcohol and while still wet plug in and out several times. Should work.
Old Mar 24, 2026 | 10:14 AM
unsuperman's Avatar
unsuperman
6th Gear
Okay awesome didn't even think about that. I'll give it a try before trying to replace it
Old Mar 24, 2026 | 11:06 AM
Tootsall's Avatar
Tootsall
Are both connections giving problems?...or only one? Might be a clue as to whether or not the issue is with the contacts.
Old Mar 24, 2026 | 11:56 AM
unsuperman's Avatar
unsuperman
6th Gear
It's both unfortunately. I did buy the car used and it was dirty on the inside with soad spilt around it. So maybe that's the issue?
Old Mar 24, 2026 | 02:34 PM
Tootsall's Avatar
Tootsall
Dang. I used to have instructions for opening up console on Gen 6 but dumped those when I went to Gen 7. Haven’t found any yet.
Old Mar 24, 2026 | 06:54 PM
Tootsall's Avatar
Tootsall
This video might help you.
Old Mar 24, 2026 | 07:28 PM
unsuperman's Avatar
unsuperman
6th Gear
Awesome! Perfect thank you
1rarees
Apr 24, 2023 08:16 AM
Curated Content Editor
Sep 26, 2018 12:27 PM
madankambo
May 11, 2017 05:34 PM
madankambo
May 11, 2017 05:33 PM
DShiekhi
Apr 12, 2016 04:42 AM
