What is this Pink PP+EPDM object in A-pillar?
Old Jun 15, 2024 | 02:26 AM
es250fsport's Avatar
es250fsport
Question What is this Pink PP+EPDM object in A-pillar?
I was doing the dashcam install and taken the A-pillar out to fish the wire so that it doesn't interfere with the airbags..
I couldn't figure out what the purpose of this pink hose looking thing..
As I was typing this.. I just remembered I have a sun roof. Is this the drain hose for the sun roof?
Old Jun 15, 2024 | 03:41 AM
ESh's Avatar
ESh
Yes, the drain hose.
Old Jun 15, 2024 | 03:53 AM
es250fsport
Thanks for confirming.
How do you flush that out?
I just mixed warm water with soap and put 500mL water each side to see if it will drain from 4 sides.
I can see the same amount of water drained which is good.
The last thing I want is to have a clogged drain hose!
Old Jun 15, 2024 | 05:17 AM
ESh's Avatar
ESh
You get this tool and clean it.
https://a.co/d/2z9yK59
You should test them all the time, for example every year if the water drain through them or not.
In your country I’m afraid you will find a lot of sand in there.
Old Jun 15, 2024 | 05:34 AM
es250fsport
Interesting.
Is there a risk of disconnecting that hose as you push that tool inside down the hose?
Old Jun 15, 2024 | 05:38 AM
ESh's Avatar
ESh
No, because this one is steel but not a hard one, but if you find out that the cable doesn't want to go then you just pull it.
Old Jun 16, 2024 | 10:48 AM
Wilson2000's Avatar
Wilson2000
I went for 13 years in my 2011 ES without ever cleaning the four drain hoses, and I never had a clog/leak, even though the vehicle was parked outside its entire life! My saving grace is there are no trees around where we normally park. Also, I'm a stickler for keeping my cars clean. On the other hand, if one parks under trees a lot and doesn't keep their car clean, they should be testing their roof drains periodically. If you wait until they clog before cleaning your drains, it could be too late and you'll be plagued with mold and electrical issues from the water damage.
Old Jun 16, 2024 | 10:52 AM
Wilson2000's Avatar
Wilson2000
BTW...don't ever use compressed air to blow out clogged drains. It can dislodge the drain tube, resulting in a massive leak.
Too, remember the drains work year-round, and when the roof is closed. The sliding roof is not designed to keep water out. Think of it as a controlled leak!
elliecm
Feb 6, 2024 04:15 PM
FWCA
NX - 2nd Gen (2022-current)
Dec 9, 2022 06:11 PM
Lakerstrg
15
Nov 10, 2022 08:24 AM
biff44
LX - 3rd Gen (2008-2021)
Aug 17, 2021 05:31 AM
