Infotainment
Old Jan 17, 2023 | 05:32 PM
fun1170's Avatar
fun1170
Default Infotainment
Why does the infotainment screen default to the home screen upon startup
Old Jan 18, 2023 | 05:15 AM
mikemu30's Avatar
mikemu30
Mine doesn't.
Old Jan 18, 2023 | 07:15 AM
fun1170's Avatar
fun1170
I haven't been able to find a way to change it. I'd like for the screen to stay where it is when I shut the engine off.
Old Jan 18, 2023 | 08:13 AM
mikemu30's Avatar
mikemu30
So if you shut down with the screen on RADIO for example, it restarts on what?
Old Jan 18, 2023 | 08:16 AM
TechNut's Avatar
TechNut
Veteran: Navy
I believe there is a setting in the menu to control this behavior, but I cannot recall precisely where it is located so you may want to explore a bit. It might also help to know the model year of your car as I understand the 2023s are a bit different.
Old Jan 18, 2023 | 10:01 AM
grp52's Avatar
grp52
On 2019 - 2022 model year's with 12.3 inch displays (i.e., those equipped with navigation), the setting that controls automatic return to the map screen is found with this [touchpad/touchscreen] menu chain: Setup [the gear icon]-> General-> "Auto Change to Screen".
I haven't tried setting that to off to see what the start up screen is after a car shut down and restart cycle so that setting's behavior may not yield the "preserve last screen display setting and use it for next start up" behavior that fun1170 is looking for.
On 2019 - 2022 model year's with 8 inch displays (i.e., those not equipped with navigation), there is a different setting than the "Auto Change to Screen" setting. Instead, there is a “Customize Home Screen” menu item at the end of the above menu chain. But a literal reading of that menu item's description doesn't suggest it will give fun1170's desire behavior of starting up to the same screen as the one displayed when the system was last shut down.
Old Jan 18, 2023 | 01:35 PM
fun1170's Avatar
fun1170
I have a 2019 es350 fsport. Screen goes from full radio to split screen on start up.
Old Jan 19, 2023 | 03:38 PM
Dallas250's Avatar
Dallas250
I use the CarlinKit wireless CarPlay and my screen always defaults to whatever CarPlay screen I used last which is usually Waze. Without the wireless CarPlay, I agree, it always goes to the split screen homepage.
Old Jan 20, 2023 | 01:49 AM
ESh's Avatar
ESh
Most of the time I choose to see the energy monitor on the left and HVAC or Music on the right but everytime that somebody calls me it goes on Navigation/compass full screen and I hate it.
Old Jan 20, 2023 | 08:55 AM
mikemu30's Avatar
mikemu30
Yeah incoming calls negate my audio presets screen option every time. Everyone please stop calling and texting me
Old Aug 1, 2023 | 11:00 AM
Spock's Avatar
Spock
9th Gear
I have a similar problem on my 2023 RX350H.
The source returs to android play every time I start the car. I have to manually to the radio. Quite annoyimg. The instructions below doe not work.
Old Aug 1, 2023 | 12:48 PM
Spock's Avatar
Spock
9th Gear
Ok so Lexus said it was normal, if you have Android auto, it will start each time you start the car.
So, I'm somewhat **** retentive and found this.
This is not a perfect solution, but there is a setting on the android auto app that allows you to change the default. The setting is under "start android auto automatically".
3 choices
1- Always (default)
2- If used on the last drive
3- Default (set by the car)
I selected 2. You have to restart the app (I just restarted the phone).Sure enough if it was not used on the last drive (not sure if used at any time or last before turning the car off,...yet) it does not start and stays on your last source.
Hope that helps someone else.
Old Feb 13, 2025 | 08:11 AM
RA030925's Avatar
RA030925
I just clean mine every other week with my spray 'no rinse wash and wax' and then a spray on carnuba car wax onto it, only using microfiber cloths (replace those cloths often). No scratches so far. Did this with my Acura ( 2yrs and no scratches) and with my Honda ( 4 years, no scratches). Friends ask me if I ever use the touch screens because they look brand new.
Old Mar 22, 2025 | 05:26 AM
Sonny3621's Avatar
Sonny3621
My biggest issue with the built-in nav is it doesn't hold your selected view. If you have the map in the angled view and then change from nav to anything else (radio, settings, etc.) and go back to the nav it defaults back to the overhead view every time and there is no way to change that.
Old Mar 22, 2025 | 11:18 AM
DavidZ's Avatar
DavidZ
I have a 2019 ES 350L with a wired, dedicated iPhone. Up until about a month ago, it would start up with the last screen used in CarPlay. After the latest iOS update about a month ago, it started up with a split screen map/music. I didn't like that, so I Googled around and found an "Automation" that starts it up on the Apple Music Now Playing screen in full screen mode.
Tommyg46
IS C
Apr 29, 2020 07:40 AM
modthispny
Dec 29, 2012 03:10 PM
yaro1
Apr 15, 2006 07:36 PM
Phil
Jan 23, 2002 08:33 PM
