Why Does My Car Ding Sometimes?
Old Oct 18, 2019 | 02:11 PM
DavidZ's Avatar
DavidZ
Default Why Does My Car Ding Sometimes?
Sometimes when I shut my car off and am leaving, the car dings repeatedly. It does this about once every 10 times I leave the car. When I close the door, it stops. When I check the (old) remote app, it says everything is OK.
I guess it's trying to warn me of something, but I can't figure out what.
Old Oct 18, 2019 | 04:48 PM
mikemu30's Avatar
mikemu30
I notice that every now and then. Same sound it makes if you leave a window open.
Old Oct 18, 2019 | 05:09 PM
DavidZ's Avatar
DavidZ
Right. When I first got the car, it made the dinging sound every time I got out of the car. But the dashboard and the app said a window was open. I opened that window and closed it, but the dinging didn't go away. It rained a couple of times, but there was no leak. My plan was to ask the dealer the next time I went in.
Finally, I opened all 4 windows all the way and closed them. The sound went away except for 1 in 10 times problem with no error code I described in the first post.
Old Oct 19, 2019 | 04:44 AM
FTBoomer's Avatar
FTBoomer
Mine shows that the door is open and dings. Well yeah the door is open, I'M GETTING OUT OF THE CAR!!
Old Oct 19, 2019 | 05:16 AM
DavidZ's Avatar
DavidZ
My car shows the door open, but only dings about 1 out of every 10 times I get out of the car.
Old Oct 19, 2019 | 06:54 AM
Mike728's Avatar
Mike728
Are you turning the car off after you open the door, or before?
Old Oct 19, 2019 | 06:58 AM
FTBoomer's Avatar
FTBoomer
Before, 10char
Old Oct 19, 2019 | 07:01 AM
Mike728's Avatar
Mike728
Before, 10char
Then I would have it checked out while still under warranty.
Old Oct 19, 2019 | 01:18 PM
jhansen31's Avatar
jhansen31
It may be that a window or moonroof is still opens and the ding is alerting you to this fact
Old Oct 19, 2019 | 01:30 PM
DavidZ's Avatar
DavidZ
If the window or moonroof were open, it would show up on the Multi-Information display and in the phone app. It doesn't.
Old Oct 19, 2019 | 01:45 PM
evan2k's Avatar
evan2k
When you turn off your vehicle, are you completely shutting down and not in aux mode? Also key battery low warning ever came on?
Old Oct 19, 2019 | 01:53 PM
DavidZ's Avatar
DavidZ
Completely shutting down.
No.
Old Oct 19, 2019 | 03:02 PM
mikemu30's Avatar
mikemu30
Im pretty sure its normal and only under certain conditions which I cant be bothered trying to figure out. If a window is open you'll get the ding and a yellow hazard warning in the cluster. This is just the ding with nothing else.
Old Oct 20, 2019 | 07:44 AM
DavidZ's Avatar
DavidZ
I can certainly see how you might say this is too trivial for you to spend any time trying to figure it out. However, it will continue to nag me until I figure it out.
I can't see how this could possibly be "normal." It's either a defective false alarm or there's something that it's trying to tell the driver.
Old Oct 20, 2019 | 08:46 AM
mikemu30's Avatar
mikemu30
Let us know what you come up with but dont lose much sleep over it. Your warranty has plenty of time left so if there's really a problem, you'll figure it out long before expiration.
