Lexus Enform iPhone message
Old Aug 18, 2019 | 05:12 PM
Stacy1436's Avatar
Stacy1436
Default Lexus Enform iPhone message
I have a new 2019 ES. Every time I get in the car, I get a message that says “Lexus Enform would like to communicate with the TOYOTA MOTOR CORPORATION Lexus ES”
It is only after I choose “Allow” that the Bluetooth works.
Does everyone have to do this every time you get in the car or do I have a setting off somewhere?
Old Aug 19, 2019 | 02:07 PM
jpreslee's Avatar
jpreslee
Yes indeed, every time. So annoying. Along with always changing the split screen which always jumps randomly to something different every trip. See my post on that but no known fixes for either.
Old Aug 19, 2019 | 02:45 PM
jaygee1's Avatar
jaygee1
Odd, I’ve never received that message?
Old Aug 19, 2019 | 03:06 PM
DavidZ's Avatar
DavidZ
I don't get the message, but I do remember allowing the Lexus Enform app access to everything it asked for when I set up the app. That's the only thing I can think of that might cause that message.
If you have an iPhone, I suggest you launch the Settings app. At the bottom of the long list should be the Lexus Enform app. You can check your accessibility settings there.
Old Aug 19, 2019 | 04:50 PM
TechNut's Avatar
TechNut
Veteran: Navy
Agreed. I have never seen this, but also recall the comment DavidZ referred to regarding allowing the app full access.
Old Aug 20, 2019 | 08:53 AM
LeeSoFL's Avatar
LeeSoFL
As long as you don't close the app on your iphone, all you need to do is hit "continue" on the car's startup menu.
Old Aug 21, 2019 | 08:28 AM
LeeSoFL's Avatar
LeeSoFL
I check today, and you don't need to "continue," upon startup. As long as the application is running on your phone, it will connect within a few seconds, every time.
I open the app in the morning, and that's all there is to that.
Old Aug 29, 2019 | 07:39 PM
markp1798's Avatar
markp1798
Default Disable Enform message on startup
Not positive this is the message you want to disable but I recall finding this soon after I got our ES. Found this on page 340 in the Navigation user guide.
1 Press the “MENU” button on the Remote Touch.
2 Select “Setup”.
3 Select “Enform App Suite” on the
sub menu.
4. Select line A to disable the message
jamestpc
12
Aug 19, 2018 04:56 PM
MEISEN529
Jan 4, 2018 12:55 PM
rcfboy69
RC F (2015-present)
Sep 15, 2015 06:30 PM
winsalem
Mar 23, 2015 04:53 PM
glepera
Sep 7, 2012 05:47 PM
