Possible Battery issue?
Old May 24, 2025 | 12:51 PM
ThaiTea's Avatar
ThaiTea
Default Possible Battery issue?
My car suddenly started to do this, I’m wondering if it’s a possible battery issue? I start it up and upon starting, it stalls a bit and the memory seat freezes so I have to select my memory seat button to go all the way for my preferred preference. Would replacing the battery be the first step in T/Sing?
File Type: mov
Old May 24, 2025 | 01:47 PM
mikemu30's Avatar
mikemu30
How old is your battery?
Old May 24, 2025 | 04:19 PM
july1988's Avatar
july1988
Get your battery check - free at all AutoZone.
Just replaced my original one at 6 years mark at Lexus, all my customizations were saved and I'm good for the next 6-7 years, guaranteed by Lexus.
Who was talking though
Old May 24, 2025 | 06:51 PM
ThaiTea's Avatar
ThaiTea
I have a 2022.. That's what I was going to just do. Head to Costco and get an AGM one. I bought the car used, so most likely it has the OEM one and needs replaced.
Old May 25, 2025 | 12:34 AM
ESh's Avatar
ESh
I think your battery is going south.
Old May 25, 2025 | 03:12 AM
zul8tr's Avatar
zul8tr
When I had my OEM battery replaced at Lexus with a new Lexus/Toyota one (free under basic warranty) the replacement warranty was stated at 2 years. How is Lexus guaranteeing you 6-7 years?
Old May 25, 2025 | 08:10 AM
tfischer's Avatar
tfischer
25 Year Member
In my experience, car batteries last for at least 3 years, and sometimes 5 or 6, depending, of course, on your use.
I used to replace mine every three years or so just to be safe, but I think newer batteries are lasting longer, and I'm driving less. I have been told that newer cars don't give a driver the early signs that they used to (slow cranking, dim headlights); they work fine up to the day they won't start the car.
After a few years, use your battery testers or visit a dealer or parts shop that will test it for you (there are two basic tests, using two different devices; one for charge, one for cranking power, or something like that. Be sure to get both done.)
For insurance, get one of those emergency battery jump chargers. They are small, and a bit expensive, but can jump start a car 5 or 10 times. It's just like using jumper cables, but without the cables and without the other car. Don't leave home without it.
Old May 25, 2025 | 08:44 AM
mikemu30's Avatar
mikemu30
I replaced mine at five years. Typically I would go four but I rolled the dice with the ES.
I doubt Lexus gives full replacement up to six years.
Old May 27, 2025 | 01:45 PM
Lesley248's Avatar
Lesley248
+1 to what tfischer said. I can't tell you how many times it has saved my butt and how many others I've helped with it. Same with a 12v tire inflator.
Exulter
Jan 1, 2024 11:07 AM
kambam3627
Jul 10, 2019 06:14 PM
Akachan LS
Maintenance
Oct 29, 2010 03:46 PM
zachpapa
Jun 17, 2010 06:47 AM
Todd
RX - 1st Gen (1999-2003)
14
Oct 27, 2004 12:49 PM
