Under car rattle
https://www.toyotanation.com/threads...video.1693657/
I hear the same noise and have a feeling it's the same thing on my 2020 UL350. Has anyone else encountered this? I took this to a local mechanic and they said everything was tight underneath; however, I'm not sure I trust their diagnosis.
Thanks!
Your report is a bit confusing to me, as you report that you "have a feeling" it's familiar to something on a previous vehicle, but you report that a mechanic who, I presume, got under the car and nosed around, found nothing loose. When your "feeling" contradicts the empirical findings of someone with training and experience in the field, the next step, I would think, would be to seek a second opinion from another expert.
Thanks!
There was a rear end rattle thread a year or so ago. Neither denise2019lexus350 or scubapr posted if they ever found a resolution to their rattling noise but in that thread's post #16 I posted a link to UltraLux22 post in another thread that had this fix Lexus service department entry:
DESCRIPTION: FOUND THE PLASTIC CAP ON THE LR TRAILING ARM FORWARD MOUNTING BRACKET HAD COME OFF AND THE CAP WA
SERVICE: DESCRIPTION: FOUND THE PLASTIC CAP ON THE LR TRAILING ARM FORWARD MOUNTING BRACKET HAD COME OFF AND THE CAP WA ~|~CUSTOMER STATES THAT NOISE WHILE DRIVING ALSO SOUNDS LIKE A LOOSE HEAT SHIELD. ATTENTION DOUG. ~|~ ~|~1307 FOUND THE PLASTIC CAP ON THE LR TRAILING ARM FORWARD MOUNTING BRACKET HAD COME OFF AND THE CAP WAS RATTLING AROUND IN THE FRAME POCKET. ATTACHED THE CAP TO THE BRACKET AND TEST DROVE, THE NOISE IS NO LONGER PRESENT. (DM) OUT MILES - 1409 READ LESS
