Brake replacement at 35k miles??
Old Feb 5, 2025 | 11:33 AM
  #46
edbro's Avatar
edbro
Originally Posted by ESh
what is the point having drilled and slotted rotors?
Drilled rotors help dissipate heat, improving performance. Unlikely to provide any benefit in a less than high performance sedan.
Old Feb 5, 2025 | 12:05 PM
  #47
Yes, less dust, and I understand having ceramic pads. But what is the point having drilled and slotted rotors?
Drilled is basically for looks but slotted is great they cut the pads if/when any inconsistencies on the surface develops. May decrease pad life slightly. Don't knock that kit and ones like it until you try it way better than OEM which frankly on a modern Toyota/Lexus is nothing special.
Rust resistance is 10x better as well.
Old Feb 5, 2025 | 12:57 PM
  #48
ESh's Avatar
ESh
I know they help dissipate heat, but what is the point of that when you have ceramic pads, which are inferior when cold?
Also, slotted and drilled rotors has smaller friction area, and they make noise when braking hard.
Old Feb 5, 2025 | 01:13 PM
  #49
Which rotors were you running that did this?
Old Feb 5, 2025 | 01:44 PM
  #50
ESh's Avatar
ESh
Centric for example.
Old Feb 5, 2025 | 03:16 PM
  #51
Denzlex's Avatar
Denzlex
Originally Posted by alextv
From what I remember new rotors have to be resurfaced also unless times have changed where they don't. ESh can probably tell us that.
Wow, how long ago was that??
Old Feb 5, 2025 | 03:46 PM
  #52
For example? Do you own a set? I've never seen Centric slotted and drilled only one or the other. I have a set of slotted Centric they are a good product, a slight hum on hard braking not that I care they have good bite.
Old Feb 5, 2025 | 08:39 PM
  #53
july1988's Avatar
july1988
Originally Posted by mmatheny
Resurfaced both front & rear - $320 front $300 rear
Hey can you pm me the full quote, I need to ask my dealer to price match, please
Old Feb 5, 2025 | 11:05 PM
  #54
ESh's Avatar
ESh
I had Centric drilled on my e39. They were noisy.
Also, look at the Mercedes cars with drilled rotors. The grooves are enormous and because of the cracks I replace them very often.
Old Feb 5, 2025 | 11:13 PM
  #55
I had Centric drilled on my e39. The were noisy.
I don't recommend Centric anymore the ones I have were new/old stock they are good quality.
edit - R1 Concepts rotor with Akebono ACT pads after about 2.5 years great rotors. No rust even after salt exposure including in the holes and slots.
Old Feb 6, 2025 | 12:54 AM
  #56
ESh's Avatar
ESh
Is this on a Tesla?
Old Feb 6, 2025 | 09:12 AM
  #57
mcomer's Avatar
mcomer
The Automatic Parking Brake is not contributing to the brake wear, it applies pressure to the pads when the rotors are not turning, no friction involved.
I personally miss the "hand brake turns" that conventional lever action applied while moving...sideways... but that is not happening here.
Nice thread on the slots and vents discussion, thanks.
sajack
LS - 5th Gen (2018-present)
Aug 10, 2025 11:58 AM
wfw
Sep 29, 2022 10:16 PM
Guilartd
RX - 4th Gen (2016-2022)
21
Mar 1, 2020 06:00 AM
ssmtsx
Nov 28, 2016 06:43 PM
