Dash Cam Installation
Old Jan 1, 2025 | 01:22 PM
JIB55's Avatar
JIB55
4th Gear
Default Dash Cam Installation
I have a 2020 es300h. I want to install a Nextbase Rear Window camera and I'm wondering whether anyone has ideas on how to draw power to it directly from rear personal lights or some other source in the back window area? I am using a Dongar Pro to power a Nextbase 622gw in the front window dash cam but would prefer not to have to install wire from front to the rear dash cam if possible. Thanks.
Old Jan 2, 2025 | 07:49 AM
Demanufacture's Avatar
Demanufacture
Running the cable to the back was surprisingly easy for my install. I ran the cable from the front, down the A pillar on the weatherstripping side, down the floorboard under the trim, all the way past the B pillar on the floor, then up the side from the floor of the c pillar to the roof and to the rear windshield. Easiest wire run that I've had to do, just make sure you have long enough of a cable. I have a A119 that come with a 6m cable I think, and that was more than enough.
Old Jan 2, 2025 | 09:43 AM
Lesley248's Avatar
Lesley248
^what he said. Running the wire is super easy.
Not familiar with Nextbase 622gw but is the rear camera part of that model? Usually the power wire is also what sends the data to the front camera too, unless it's wireless.
Old Jan 2, 2025 | 10:32 AM
JIB55's Avatar
JIB55
4th Gear
Thank you, I will do it that way
Old Jan 2, 2025 | 10:34 AM
JIB55's Avatar
JIB55
4th Gear
Yes, the power and I assume data for the rear camera plugs into the 622gw front camera, so I am going to give it a go, thank you
Old Jan 2, 2025 | 03:33 PM
JIB55's Avatar
JIB55
4th Gear
One questionl: in routing down A pillar on weatherstripping side does that involve crossing over the curtain air bag? Do you need to pry back cover of pillar to route so it doesn’t cross air bag? Thanks
AustinTex
Jul 10, 2023 04:13 AM
Sherl
May 24, 2023 06:13 AM
Cwiok71
GX - 1st Gen (2003-2009)
Aug 2, 2021 03:56 PM
af7rzm
Mar 21, 2020 10:43 AM
EJ255t
Sep 28, 2019 09:49 AM
