USB ports not working
Old Dec 13, 2024 | 11:59 AM
Saul350's Avatar
Saul350
10th Gear
Default USB ports not working
Hello
I have a 2019 Lexus ES350 F Sport and the center console USB ports suddenly are not working
I’ve tried to change the cable but did not work
any thoughts?
Thanks
Old Dec 13, 2024 | 09:33 PM
dezymond's Avatar
dezymond
I'd try bringing it in to the dealership. Even if you are out of warranty, they may repair it in good faith. If not, then I'd really start doing some research.
Old Dec 13, 2024 | 11:24 PM
Saul350's Avatar
Saul350
10th Gear
Is there any way to just pop up the ports and replace the parts? or should I remove the whole center console?
Old Dec 13, 2024 | 11:38 PM
gcvt's Avatar
gcvt
Have you checked the fuse(s)?
Old Dec 14, 2024 | 04:38 AM
Saul350's Avatar
Saul350
10th Gear
there is no specific fuse for the USB ports
Old Dec 19, 2024 | 03:25 AM
Saul350's Avatar
Saul350
10th Gear
Any thoughts?
Old Dec 19, 2024 | 03:55 AM
ndunn's Avatar
ndunn
Disconnect the battery and reboot?
Old Dec 19, 2024 | 06:22 AM
mcomer's Avatar
mcomer
While the rear footwell area USB ports on the back of the center console are not wired
for signal (only charging) you should check if they are still connected. If not, it would seem
that you have somehow unplugged the whole console. If they work OK for charging, then
you may have a plug on the back of the head unit disconnected.
Old Dec 30, 2024 | 02:07 AM
Saul350's Avatar
Saul350
10th Gear
I just bought a new ports for about $150.
Should I remove the whole center console for replacing the ports or is there any way to replace it without removing the center console?
thanks
Old Dec 30, 2024 | 11:53 PM
Saul350's Avatar
Saul350
10th Gear
Any thoughts?
Old Dec 31, 2024 | 08:00 AM
Lesley248's Avatar
Lesley248
Originally Posted by Saul350
Any thoughts?
Don't have an answer for you but here's a video on
to take apart the center console and dash, if you didn't already know how to.
If it's the ports in front, by the shifter, I think(?) you might be able to slide the knee pad covering on the center console and that'll give you some space to see where the USB is. Maybe you'll have enough room to check the connection and/or pop it out? Sorry, not really helpful.
Old Dec 31, 2024 | 08:45 AM
DavidZ's Avatar
DavidZ
thanks
Why do you think replacing the ports will solve the problem? I'd give it a 50% chance at best.
Old Dec 31, 2024 | 08:49 AM
Saul350's Avatar
Saul350
10th Gear
Because I checked EVERY possible resaon for that
Old Dec 31, 2024 | 09:22 AM
DavidZ's Avatar
DavidZ
If it's a mechanical problem, I don't think it's likely that both ports would fail at the same time. Are you aware that the system will only recognize one USB device at a time?
Old Dec 31, 2024 | 09:50 AM
Saul350's Avatar
Saul350
10th Gear
I think some water or coffee just dripped in the ports
