triple beam ?
Old Jun 2, 2024 | 02:07 PM
DocEnuf's Avatar
DocEnuf
Default triple beam ?
CAN Triple beam headlights be installed on a ES 350 , 2020 up models.
Old Jun 2, 2024 | 02:55 PM
mikemu30's Avatar
mikemu30
They were and are optional. You mean install on one that didn't come equipped with them? The parts alone are incredibly costly. I don't know if they are plug n play though. Sort of doubt it.
Old Jun 2, 2024 | 03:35 PM
bc6152's Avatar
bc6152
IIRC this question has been asked previously. Very expensive job. Do a search and you can get more info...
Old Jun 2, 2024 | 04:29 PM
Jersey5974's Avatar
Jersey5974
If you just want the look of them, you can DIY aftermarket them for about $1000 and 1-6 hours (depending on how quick you are with the bumper removal process). Keep in mind, the aftermarket ones are looks only, as they are not going to be as high quality nor have cornering.
An independent mech might put them in for you for an hour or two worth of labor, but I don't have experience with that.
The OEM ones would likely cost 3-5k.
Old Jun 4, 2024 | 09:10 AM
DocEnuf's Avatar
DocEnuf
Default could not find on serch
I did a search prior to posting and nothing came up. I will look again. Sounds like I need to keuep looking for a car that comes with this option vs changing it out.
Old Jun 4, 2024 | 09:26 AM
scubapr's Avatar
scubapr
Here's one: https://www.clublexus.com/forums/es-...eadlights.html
Old Jun 4, 2024 | 10:12 AM
DocEnuf's Avatar
DocEnuf
Default thank you for replies,
AFter reading the other threads as well as this one. I am not going to try to change out headlights with Triple beam ones. I will just purchase a car that came with them. Thank you all for your replies and information.
Brian
Old Jun 4, 2024 | 07:44 PM
dr3wski's Avatar
dr3wski
I sure hope so because my triple beams are the best headlamps I've ever had in a car. I used to work in stage lighting and thinking about what they do and how well they do it (sleakness) is impressive.
beachbum21
Mar 18, 2023 02:37 PM
RichardVPO
ES - 7th Gen (2019-2025)
May 23, 2022 06:15 AM
Aleila
Dec 21, 2015 02:24 PM
heelor
Lighting
May 11, 2008 06:27 PM
bigjoe871
20
Oct 17, 2007 11:26 AM
