Slippery wireless charger
Old May 26, 2023 | 12:32 PM
4ernik's Avatar
4ernik
8th Gear
Default Slippery wireless charger
Anybody there dealt with slippery wireless charger pad in 2023 ES? Every time I press gas my phone slips from the charger pad and it's quite annoying.
I wondering if anyone can recommend decent anti-slip tape or pads. There is a bunch on amazon, but maybe someone has first had experience with those.
Old May 26, 2023 | 12:54 PM
Vertdafert's Avatar
Vertdafert
No but I noticed mine does not charge my S23 ultra consistently in an otterbox case. I am just going to get a short usb-c cable and run through the armrest. Use the charging area more as just a convenient phone docking location.
Old May 26, 2023 | 05:02 PM
ESAsh's Avatar
ESAsh
When you touch the charging pad it actually has a grippy material on it, all you need is a case that is also suitably grippy. My Samsung S23 Ultra is in a Samsung leather case and never slips or loses charge on the pad since it is also a thinner case.
Old May 26, 2023 | 07:05 PM
dezymond's Avatar
dezymond
My 22 is pretty slippery, especially after I've wiped it down to clean.
Old May 27, 2023 | 08:54 AM
Ltvscout's Avatar
Ltvscout
I can't get my S22 Ultra to charge at all, with or without the Otterbox on it. I've tried moving it all over the pad. It connects for a couple of seconds then disconnects. My wife's S9 works just fine so I know the wireless charger is working.
I ended up buying a 1.5ft USB-C to USB-C cable from Monoprice. It's just the right length and goes through the pass-through in the armrest perfectly.
Old May 27, 2023 | 11:55 AM
dezymond's Avatar
dezymond
The coil that they use in the qi charger is tiny. I finally found the specific spot in my car which is all the way to the left side close to the power button on the charger. However, if it moves from that spot slightly then it stops charging. I bought a wireless adapter for Android Auto, but if I gets moved out of place by either accelerating too hard or making a left turn, then it's more cumbersome to open the compartment and move the phone back. I've considered a few times to switch back to the cable connection because of it, especially after cleaning the charging pad and noticed it was much more slippery than before.
Old May 27, 2023 | 03:00 PM
Ltvscout's Avatar
Ltvscout
With the '23 the wireless charger is a different design and it's outside the compartment.
Old May 27, 2023 | 04:15 PM
dezymond's Avatar
dezymond
I know, but the coil on the qi charger is as small as before. I'm glad they moved it to a better location, but the main issue remains the same, it's not a reliable charger.
Old May 28, 2023 | 11:22 AM
asadani's Avatar
asadani
I have noticed that the wireless charger is either very slow or ineffective. On the positive side, the usb c outputs in the center console are rapid chargers
Old May 28, 2023 | 12:08 PM
dezymond's Avatar
dezymond
It is slow, but it'll actually charge if you're using wireless AA/CP. I think it may be a 7.5w charger.
Old Aug 11, 2023 | 10:19 AM
MrBigE's Avatar
MrBigE
8th Gear
I just bought my 2023 ES this week and I noticed this problem immediately - glad I'm not the only one! I have an iPhone 13 mini, so there's lots of space for it to slide around; nearly impossible to keep it anywhere near centered.
What is working for me is a small rectangle of foam/perforated toolbox drawer liner! It's black, has lots of grip without being sticky at all, and was pretty darn cheap (you can find some for like, $7 at a Harbor Freight). It does add some distance between the phone and the surface, so the auto-centering of the charging coil doesn't sense the phone unless it's almost dead center, but for now it works good enough for me.
I wonder about the effectiveness of such things as a small patch of moleskin...
User 41924
Automotive Care & Detailing
Jan 15, 2016 12:11 PM
19ES250
Jul 16, 2012 09:35 AM
hmkim
Maintenance
Jun 21, 2010 06:54 PM
569jason
Wheels, Tires & Brakes Forum
Jun 15, 2008 07:48 AM
nighthawk
Apr 18, 2007 02:14 PM
