2013 multi-information is not working
I drive 2013 ES350 and multi-information display is not working correctly. "after refueling" & "average speed" display keep start over from zero at every single start.
Of cause, "average" display is keep starting over from zero even I did not touch and keep hold the display button. please help me.
Thank you in advance
I know that you can reboot the audio/navigation/information system by pressing and holding the volume down button on the steering wheel for approximately 20 seconds. I don't know whether the multi-information display is included in the reboot, but it might be worth a try to see if it is and if a reboot might solve the problem.
Also, I don't have my 2013 ES any longer. So, I can't tell you exactly where it is, but, in the settings for the multi-informational display, there is the option to re-set all of the multi-informational settings to their defaults. Doing that is another thing that might be worth trying.
I already did unplug the negative as L3XUSFAN recommended and holding the volume down button on the steering wheel as lesz recommended. However, both of way can not solve the problem. Do anybody have other idea?
I had a similar problem a couple of years ago - intermittent resetting of the display when re-starting the car. Dealer tried a few things and was then advised to go into the dash, I declined on that and they offered me a new battery just for my aggravation I guess. The problem was immediately solved never to return. I thought at first removing the battery might have caused a reset but they keep power to the car during battery replacement so I was left with the assumption that the battery which passed the load test was failing with in intermittent shorting condition. And the battery was only about a year old at the time. It's worth a try.
Dave Mac
Dave Mac
sclui56
LX - 3rd Gen (2008-2021)
Mar 7, 2020 02:44 PM
clynnh1230
Jul 18, 2013 05:28 AM
ramshyd
Dec 28, 2012 09:36 AM
johnnunez2
Oct 26, 2011 04:25 AM
