ES - 6th Gen (2013-2018) Discussion topics related to 2013+ ES models
Maintenance light
Old 05-24-14, 01:33 AM
Poppa
Poppa's Avatar
Default Maintenance light
Hey guys... right now my car is approaching 4K miles.. but in a couple of weeks my wife will be taking a long trip that will easily put her over the 5K mile mark, and If I was told correctly, that means the "maintenance" light will come on.... is there a way I can reset that before she leaves, or at least a way I can tell her how to reset it when it comes on while she's out of town.. Kinda silly to have the maintenance light come on every 5K when they suggest 10K oil changes. Thanks guys, I appreciate any info you have..
Poppa
Old 05-24-14, 05:08 AM
jim256
jim256's Avatar
You can reset it yourself now, and it will start another 5 k countdown. It's in the manual. Same situation if you went to the dealer early for a service or oil change.
Old 05-24-14, 06:21 AM
lesz
lesz's Avatar
Received 1,011 Likes on 691 Posts
With power to the vehicle turned on, change the odometer to "trip A".
Turn off power to the vehicle.
With your foot off of the brake (so that the engine does not start), press and hold the (trip) odometer re-set button while pressing the start button to turn power to the vehicle back on. Again, do not start the engine.
You should see the odometer reading flashing a sequence of dashes. When the flashing stops, the maintenance remainder will have been re-set, and it will come back on again in 5000 miles.
If my explanation is not as clear as it could be, the instructions are in the manual in the maintenance section.
Old 05-24-14, 11:06 PM
Poppa
Poppa's Avatar
Jim, / Lesz.... thanks so much for your help... I got it now..... appreciate your help...
Poppa
Old 05-27-14, 02:17 PM
Arty101
Arty101's Avatar
Thanks Lesz for that step by step procedure. You saved me some time in looking for that since I'll be using it for my 15,000 miles coming up.
I don't plan to bring it in to the dealer but will check all fluids, and maybe skip the tire rotation altogether. That'll save me probably $150 for this mid-non service check.
osofine149
IS F (2008-2014)
31
01-14-21 10:56 AM
curio
09-22-17 11:27 AM
ddoo3105
GX - 1st Gen (2004-2009)
06-13-17 04:55 PM
FrOHiKE
02-23-16 05:55 PM
Bluespook
04-01-13 10:13 AM
Quick Reply: Maintenance light
