New tire comparison
Old Jan 11, 2026 | 02:53 PM
Rilcoat's Avatar
Rilcoat
9th Gear
Default New tire comparison
I am looking at buying new rubber michelin for my 2015 es350. I have 17 wheels now. My oem spec is 215/55/17. Heard lots of guys do 225/55/17. Softer ride. My ride is good with 215.
My question does the 225 improve handling (less vague)
the other option is 235/50/17 or 245/5017 (little taller)Has anyone tried that and how has that been for handling?
Old Jan 12, 2026 | 03:48 AM
brucelee1's Avatar
brucelee1
In my experience, the quality of the tire matters more than the smaller size differences. Tire Rack can provide ratings on ride quality/comfort. I did go a slightly taller tire and did feel that made for a more comfy ride.
Old Jan 14, 2026 | 05:54 AM
Les350xus's Avatar
Les350xus
Getting the 225/55/17 will not improve handling. You are adding more rubber, so it maybe more comfortable, but steering response will likely be more vague.
If you want better handling with the 215/55/17, just look for a tire that supports those characteristics.
Example: https://www.tirerack.com/tires/tires...omCompare1=yes
Old Jan 15, 2026 | 05:54 AM
st1800's Avatar
st1800
Try Sport Mode for reducing Vague feeling.
Old Jan 15, 2026 | 06:55 AM
mcomer's Avatar
mcomer
The Drive Mode "Sport" only changes the throttle and shift points. The comparatively rare ES F-Sport Handling (not ES F-Sport Design) has adaptive suspension and can change the Drive Mode to Sport Plus and tighten the shocks.
Old Jan 16, 2026 | 06:01 AM
autotech13's Avatar
autotech13
It also tightens up the steering, which you should know if you tried it.
Old Jan 16, 2026 | 11:32 PM
koushikmurali's Avatar
koushikmurali
10th Gear
I'd go with a 235/50/17 instead for handling. 225/55/17 has a bigger circumference than stock and as a result more sidewall which will create more distance between you and the road so itll be more comfortable. 235/50/17 keeps the same circumference, decreases sidewall slightly but gets wider which is what youd want. I have continental extremecontact dws06+ 235/50/17 coming from the same tire but stock size and it is so much better to take turns and not have to wait until the wheels are fully straight to floor it without spinning the wheels. Also, a benefit i noticed was that if im in a standstill in one lane but the other lane is wide open, i can turn the wheel and floor it at the same time without hesitation whereas with stock tires i'd have to be more careful and can only really floor it after ive turned the wheel and began to angle out of the lane. My steering feel is generally just tighter and my sport mode feels very planted. I can feel bumpy roads a tiny bit more but honestly thats if im really trying to pay attention and at this point i cant remember what stock is like, its still comfortable as always. If you're trying to go for handling, you also need good tires, not just sizing up so id go with a UHP tire that fits your budget.
Old Jan 31, 2026 | 07:32 PM
Rilcoat's Avatar
Rilcoat
9th Gear
Thanks for the reply. I was looking at the continentals as well. I will look into the tire size you mentioned. I also have the opportunity to buy a set of 18 in home wheels and may go that way for summer.
olddog
Wheels, Tires & Brakes Forum
Jul 15, 2007 08:15 AM
e-man
Dec 15, 2006 02:15 PM
teeque
Wheels and Tires Classifieds
Nov 29, 2004 03:44 PM
teeque
Oct 31, 2002 04:35 PM
