tranny shot, need advice
#31
I don't think your mechanic have access to TIS and Techstream and has done all the necessary procedures.
E.g.PERFORM A ROAD TEST SO THE TCM CAN ADJUST
Note
Strictly obey all speed limits and traffic laws when performing the following activities.
Note
Memory reset can only be performed using GTS.
Tech Tips
When controlling the automatic transmission and engine, the TCM (ECT) stores vehicle condition parameters in memory.
Therefore, when replacing the automatic transmission assembly, valve body assembly, SL3 shift solenoid valve, SL4 shift solenoid valve, or TCM, a memory reset must be performed so that the TCM can store the new data in memory.
Note
- Warm up the engine.
- Turn off the ignition.
- Connect GTS to DLC3.
- Turn on the power (IG).
- Turn on GTS.
- Enter the following menus: Powertrain / ECT / Data List / Throttle Position from EFI.
- From a stationary position, accelerate to the maximum speed possible by opening the accelerator pedal 15% or less. While driving, maintain a constant angle of the accelerator pedal.
Tech Tips
"Throttle Position from EFI": no more than 15% - Repeat the previous step until the jolt when shifting into gear disappears.
- From a stationary state, accelerate to the maximum possible speed with the accelerator pedal angle corresponding to the opening degree of 25-35%. While driving, maintain a constant angle of the accelerator pedal.
Tech Tips
"Throttle Position from EFI": 25-35% - Repeat the previous step until the jolt when shifting into gear disappears.
Note
Tech Tips
- The following describes how to perform a reset.
- Turn on GTS.
- Enter the following menus: "Powertrain / ECT / Utility / Reset Memory". Then click "Next".
Note
After resetting the memory, be sure to perform the previously described "Perform a road test so that the TCM can make adjustments."
#32
so my granny went last July, no warning, I paid $5640 for a tranny from japan which i was told only had 26000 miles on it. Guarnteed for 1 yr, but the mechanic said he would back me up if needed,?. Mine didn't give ant indication, I was on the highway also and all of a sudden it wouldn't go. Love my 2013 with 169000 miles on it so I paid for the repair.
