Power Steering FLuid / Trans Fluid
Valvoline Max Life ATF Dex/Merc, in the red bottle, is also compatible, full synthetic, and $17 at Walmart for a gallon. If you are going to put a quart of synthetic, most mechanics would say to flush out the OEM PS fluid, which is not synthetic. You will need at least another quart to flush out most of the OEM fluid.
Im having a isue with my lexus es 350 2008 the power steering is over heating
My lexus power steering reservoir looks dirty also it has a cheap power steering fluid that im going to replace with atf fluid
