Driving vibration: felt throughout car
Old Sep 17, 2015 | 04:35 PM
ronnymo's Avatar
ronnymo
Default Driving vibration: felt throughout car
I'm having a vibration feeling while driving. The dealership has replaced both lower control arms, bushings, and the right side drive shaft. They have told me that it is caused by my rims and tires. So I purchased new rims and tires and that has not fixed it. Thoughts?
Old Sep 17, 2015 | 06:50 PM
Lexi66's Avatar
Lexi66
Curious. What mileage on your ride?
Old Sep 18, 2015 | 04:37 AM
ronnymo's Avatar
ronnymo
There is 125,000 on the car.
Old Sep 18, 2015 | 11:15 AM
IndyGX's Avatar
IndyGX
I've had issues with the balance of my front wheels/tires that caused vibration in the steering wheel...with brand new tires. Took the tire shop 3 tries to balance the tires correctly and now the vibration is gone. Don't rule out a bad balancing job on the fronts.
I knew to keep after them because I rotated my tires from the back to front and the exact symptom reduced. didnt go away, but reduced, telling me that it was something about the balance of some of the tires/rims that was causing it.
Old Sep 18, 2015 | 11:22 AM
jkayca's Avatar
jkayca
Wheel bearings? Or would they have been replaced when they did the control arms, bushings etc?
Old Sep 18, 2015 | 12:16 PM
ronnymo's Avatar
ronnymo
The vibration is not just in the steering wheel, but in the whole car, you feel it in the seat and the pedals and steering wheel. It doesn't matter if the car is under load or just cruising down the road. It's more prevalent at about 60 to 80 miles per hour.
Old Sep 18, 2015 | 12:18 PM
ronnymo's Avatar
ronnymo
I don't believe that they have replaced the wheel bearings. That's the next replacement.
Old Sep 18, 2015 | 04:04 PM
ESh's Avatar
ESh
You have unbalanced tires or bad driveshaft.
Bearings will not shake, they just make roaring noise.
Old Sep 18, 2015 | 06:06 PM
ronnymo's Avatar
ronnymo
When I had my stock rims, I had 4 different sets of tires. 3 different brands of tires. The vibration was the same with all of them. The right side driveshat has been replaced, so I will talk to the service dept about the left side. I still have a Warrenty up to 150K.
Old Sep 19, 2015 | 07:15 AM
mlacomb's Avatar
mlacomb
Any pulsing on the brakes upon application? If so, could be frozen caliper glides + warped rotors. I've dealt with that twice and it's happening slowly again, given that the rotors are now a little thinner after turning twice.
Old Sep 19, 2015 | 08:05 AM
ronnymo's Avatar
ronnymo
I had my brakes done twice, thinking that may be a cause. However, the vibration or pulsing stayed the same.
Old Sep 20, 2015 | 12:35 PM
mvpvending's Avatar
mvpvending
Default es350 lunges forward when slowing down
i have a 2009 es350 that seems to lunge forward when its slowing down..it wont do it if i put it in neutral tho..i only drive it in automatic not sport mode and have reset ecu but it hasnt helped ..any help much appeciated..
wrigbay
NX - 1st Gen (2015-2021)
Dec 29, 2017 02:47 PM
rvkbj2345
Wheels, Tires & Brakes Forum
Jan 21, 2014 07:18 AM
mndaves
Oct 9, 2008 09:34 AM
TimDimman
Suspension and Brakes
Sep 17, 2002 01:59 PM
