Radiator Leak/Corrosion
Hi, I own a 2007 Lexus ES350 with it having a total of 111,176 miles. Upon my mechanic diagnosing a broken engine motor mount, he informed me that I have a leaking radiator pointing out all of the pink corrosion pictured
I never see coolant fluid on my garage floor due to having a timing cover leak only seeing oil spills. I checked the radiator cap and the coolant isn’t to the top which explains why my heat in the winter from time to time has been cutting in and out working intermittently as I have been driving like this for the past couple winters now if not longer
Can I just fill the radiator up with coolant as needed on a regular basis and continue to drive like this or does this radiator have to be replaced right away and can it lead to any other serious issues? Also, while I replace the radiator and pay for the labor would it be wise for me to replace the water pump as well since it’s in the vicinity or should I just wait until the water pump goes bad and then replace both the radiator and the water pump as I know that that is a very expensive repair. (I regularly changed my engine coolant as part of my maintenance if that helps)
Is it even worth keeping this car and is there a lot of life left at this stage or is this only the beginning where I will get hit with problem after problem and repair after repair with the car turning into a money pit?
The car still drives like a brand new car and shifts smooth with no noise whatsoever but has the
-timing cover oil leak
-1 broken engine motor mount
-leaking radiator
I read up and see that transmission issues happen around this mileage mark as well as water pump issues requiring replacement
Extremely appreciative for each and every response 🙏🏻
There are a lot of things you can start swapping on a very old car just “in case”, and it can quickly drain your wallet.
failed radiator and motor mount are normal considering the age. The car is 18 year old,
so probably more things will be failing, impossible to tell when….
yes, lexus can do 300k miles, but time takes it toll
even when miles are low
The early 2GR (both flavor) engines came w/defective pumps from Aisin right out of the factory. Many IS, GS, ES engines have been lost because of this; rapid overheat with accompanying internal engine Chernobyl-like action. Many/most wp’s were replaced c. 2012/2013 when Lexus did a TSB/recall on this. OP needs to verify that was done via mylexus.com. If not, then yes, it needs to be done along with the Rad.
OP - any mechanic can look at your existing wp and tell if it’s original or not. You cannot r&r those bolts and that assembly and not leave obvious tell-tale signs. But it WILL be recorded in the Lexus data if it was done by a dealership back c. 2012/2013. Also, last time I checked, RockAuto had some OE quality GMB pumps for these for cheap; like $65 or something. Great deal on a quality part. Put in a new oem (Aisin) thermostat while the job is being done. The hoses are probably fine; they are high quality and last ages more, but check them.
Ask yourself: "How much would I have to spend to get a decent replacement vehicle that I wouldn't have to spend any money on (including tires, brakes, spark plugs, etc)? $15k, 20k, 25k?"
All cars require maintenance and repairs.
I just wasn’t sure if this 1st generation model had some other major part(s) to replace or major service needing to be done for it’s 100K mark maintenance like something else costly and a big repair besides a water pump or radiator etc, that I wasn’t aware about. I do realize all cars require maintenance.
Also, does anybody know a cheap fix for the timing cover oil leak? A mechanic recommended Blue Devil Oil Stop Leak and I tried it with it not working, the company is saying I need to drive like 300 miles in order for it to take effect. I want to try a cheaper alternative/fix rather than pay thousands of dollars as it’s a very expensive job. It’s leaking super slow and I never once had to refill oil or be at danger of losing heavy oil.
Basically want to know if I should get rid of it now before I have to put more money into it, because it’s honestly not an expensive car at this point so don’t want it to become a money pit. If I put in a new radiator and replace the motor mounts I am hoping that no other big repair comes up? I get it it’s hard to predict the future and the thing is old but I basically put 3K miles on it a year cause I work from home and only do small city driving with it being my only vehicle. Thank you for everyone’s input as this forum is seriously gold filled with extremely helpful and knowledgeable individuals as I should have been on this long ago 🙏🏻
