Toyota Window Motor Intercompatibility
Old Apr 8, 2021 | 08:18 AM
TEQ's Avatar
TEQ
Default Toyota Window Motor Intercompatibility
Hi, Sorry if this is a repeat, from my quick searches, I haven't found the info/thread that addresses my question. If it's been addressed please direct me to the proper thread.
I just bought a used '05 ES330. It seems mechanically sound, but needs lots of work for minor stuff. For example, the rear left window motor appears to be shot.
The "Lexus" window motors for '02-'06 ES cost about $200 everywhere I've seen, but an '02-'06 Camry window motor would be much cheaper. Since they're the same platform and the parts appear identical, would the Camry window motor be a drop-in replacement? Or would they be incompatible with my ES?
Old Apr 8, 2021 | 11:39 AM
Arsenii's Avatar
Arsenii
Hello,
Here you can find all the Part Numbers for your vehicle. Unfortunately, it seems like they are not compatible, the arm length is different. The way to tell for sure is to take your regulator off and compare it to the one you can find at the junkyard, any 4th-gen Camry or 2nd-gen RX300 would work. Also, I found a drawing with all the dimensions for the regulator off of Camry, in case if that would help.
Hope this helps and best of luck!
Old Apr 9, 2021 | 12:12 AM
Oro's Avatar
Oro
Why do you think that?
There are a lot of instant/simple fixes. how did you diagnose that?
djeddieo
Apr 30, 2022 09:34 AM
Lexuslver
Jul 30, 2019 03:51 PM
wcb1044
Jul 21, 2017 08:17 PM
Robles84
May 29, 2017 12:09 PM
dinkel41
Aug 28, 2012 10:28 AM
