Transmission Question
03 Lexus ES300 with 98k miles and having an issue where transmission hesitate at random times when accelerating from full stop. Had transmission drained and filled, transmission filter was changed, and no error codes. Just checked transmission fluid and everything looks normal. Took it to a local shop and they couldn't find any issue with the car. Can anyone help?
Hello,
It is a normal situation for that generation, it was one of the first entry into Drive-by-Wire system for Toyota, so pretty much all of those cars up to a facelift in 2004 have some lag to them, you can learn more about it and ways to fix it here.
Hope this helps and best of luck!
Some do experience lag in certain driving situations, particularly stop and go. Usually not ALL the time. You say it's random so that fits possibly.
Was it doing this BEFORE the service, or afterwards? (not clear)
Was the fluid level checked with the car RUNNING?
When I ran some LV fluids (Maxlife, Mag 1 LV) in it, the lag was present. In the last 100k miles, I've used only T-IV* and it has been flawless.
*T-IV was the factory fill and is also known as 3309 (from Mobil, who developed it), and "TLS" by Idemitsu. "JWS3309" is the factory technical specification from Mobil. Mobil actually makes the Toyota or Lexus branded "T-IV."
Hey Oro, So, are you suggesting a drain and refill with "T-IV" if the transmission has Maxlife in it (which has been the suggested fluid to use in this forum)? Will that help or will the transmission need a full exchange? IE Maxlife out "T-IV" in.
koreywill
koreywill
And of course all the mounts need to be solid - especially the dog bone up top but also the L/R mounts (near the CV joints, so technically fr/rear given transverse orientation), to keep from having hard shifts and periodic weirdness.
I have three other personal/family cars I maintain with T-IV as the original fluid - all with Aisin AW33/AW50 transmissions, 2004-2007. IME, T-IV is better in them than a LV (low visc.) fluid like Toyota WS, Maxlife, etc. Other family members have noted the difference, even w/o me asking, or prompting what maintenance I had done (so a true blind test). I do not think MaxLife is bad fluid, it's just not ideal for these pre-LV fluid designed Aisin transmissions.
You can pump out most of the pan volume from the top fill tube (I think about ~3.3 qts this way vs. close to four if you drain) if you have a hand or powered pump, I've done it that way the last few times so as to save lifting and crawling around. I need to do the AW33 in one of my parent's cars this week, actually - it's been just over 30k (now at 132k). I did it at 66k, with MaxLife, no real change (as expected). I did it next at 99k w/T-IV and it was a big improvement. Curious to see how it reacts this time. I am going to drive it tomorrow and maybe tow a trailer/motorcycle. That will let me establish a feel for it (I do not drive this car often at all) before the drain/fill with T-IV.
Just checked all the Auto Zones in my area and TLS is not available. Must have sold out completely at that price. I'll keep looking for a good price on the TLS by Idemitsu and the JWS 3309. I've only got 10k on my most recent drain and refill (powered pump) so I'll probably wait until 15k or so.
Just to be sure, Oro, are you talking about the Lubegard Synthetic ATF 10 oz in the Red bottle?
As always, thanks for your help. Much appreciated.
The biggest benefit in these cars IMO is actually running the Lubegard PSF in the PS system more so than in the AT; it helps with the problematic hoses and high-heat problems.
It is widely attributed to Ronald Reagan but moreso his (administration's) ballistic missile strategy. Funny thing, I have a pic of Reagan and I talking about shuttle launches. I'm going to try to find that pic and digitize it; my mom and I were actually talking about it a few days ago.. (really).
Yep! Regan. Trust but verify are good words to live by when doing repairs. "Trust but verify that drain plug is in before pouring oil in, trust but verify that all tool are out of the engine bay before slamming hood, trust but verify that filler caps are on before starting engine, and on and on. Also applies to a whole lot of other stuff in life. Simple but true: Trust, but verify.
