Vibration when accelerating
Hi to all of you, I recently got my hands on a 2011 ES 350, and I'm having a slight issue with my car. At first, the car was shaking really badly as I would press on the gas pedal and as I would slow down. But I went ahead and changed the rotors on the front. The shaking has mellowed out a little, but the shaking there a little as I would speed up it's not as bad as before. I have already had the tires Rotated and balance and alignment done at Lexus of Orlando. I have seen other forums on here about the issue.
My friend Rasheed did say it could be CV joints. But once I changed the front rotors, and showed him how everything calmed down he tossed that out the window. How could I tell if my wheel is bent, I did do a tire swap as a first step with the shaking since the tires on my Passat was new Cooper tires. I swapped the Passat onto the ES and took the Michelin off
Thanks for the help guys, sorry for the late reply! So what I did was buy rebuilt CV's from Rockauto parts from Cardone, the right CV I had to send back because it was damaged and had to spend $100 on top of the $400 labor, everything seems to be fine but, when holding the car a little over 40 around 41 or 43 there is a little vibrating going on and vibrating when I slow down it only happens when it's slowing down around the speed of 43 to 40 and stops. but everything else seems to be fine. Also as anyone had a transmission service done at 165k my next oil change is at 165k and wanted to do a tranny service, I can't find any records if has been down or not.
Lexus1989
16
May 22, 2015 01:58 AM
