Temporary High Idle
Old Jul 17, 2020 | 08:59 AM
Wildtirkey's Avatar
Wildtirkey
Default Temporary High Idle
Please forgive me if this has been discussed before.
My car idles at about 1500rpm for about 4-5 min. even when its 90 degrees outside then drops to 750rps after.
If I engage drive or reverse it does not jerk and the Idle returns to normal. Have tried spraying wd 40 around the vacuum lines to no avail.
Has any one else had this problem and solved it?
Old Jul 20, 2020 | 01:41 PM
Arsenii's Avatar
Arsenii
Hello,
From my understanding, it is normal for ES300 to do that; all ES300 that I know of have that issue feature, including my 2000 Lexus ES300. It is probably there to warm up the engine quicker, in case if you are stationary. It is generally not recommended to wait until the car will warm-up on its own, since it may cause premature wear. Below is a link where this issue was discussed.
Help me diagnose a cold idle issue
Hope this helps and best of luck!
Moarpower
Aug 21, 2017 02:58 PM
sydtoosic
May 30, 2012 11:35 AM
Papi
Nov 1, 2008 07:10 PM
nagasakki
Jan 21, 2005 05:09 PM
rbini100
May 25, 2004 09:06 PM
