Instrument Panel
hi
my socket base for the bulbs in the Instrument Panel are all burned out also
can anyone help
whats the part number for the socket base, or where can i buy some. i need the ones that light up the backlight, please help thank you
can anyone help
Originally posted by squarehat
Is it just the backlights? If so, there's a way to replace them. Run a search, you should be able to find the thread. If the pointers are going, that's a different issue.
At any rate, either a junkyard or Ebay is a good start in finding the replacement parts for the instrument panel.
As far as upgrading the instrument panel of the 1st-gen ES to that of the 2nd-gen ('97-'01), I don't believe it's possible because the electrical configuration is different between them, and the needles light up electronically on the 2nd-gen ES, which seems to be more reliable and long-lasting than the LED needles of the 1st-gen ES.
The clusters are identical to the sc clusters electronically. anything that can be done to the SC can be done to the ES.
there are some internal pics here , as well as bulb replacement sizes and numbers.
https://www.clublexus.com/forums/sho...threadid=88406
ITAngel
RX - 3rd Gen (2010-2015)
13
Apr 9, 2023 06:21 AM
