B1276 code
Old Nov 15, 2019 | 10:02 AM
danielnas's Avatar
danielnas
Default B1276 code
Hi I recently scanned my 08 es350 with an OBDII module and I got B1276 and B2413 on it. B2413 is related to swivel headlight motor and B1276 could be related to the headlight switch poistion. I don't see anything wrong with the car although I have these two codes on. can anyone explain why am I getting these two codes and what can I do fix them. tried to reset them once but they came back on. I'd like to fix this myself.
Old Nov 15, 2019 | 12:14 PM
nevernu's Avatar
nevernu
DTC B1276 is a Power Mirror Control ECU Communication Stop. trouble areas incl:
1. Open or short in CAN No. 3 J/C and outer mirror control ECU
2. Outer mirror control ECU power source circuit
3. Outer mirror control ECU
4. Wire harness or connector
other than that I dont see any relation between the two except the comm bus. Usually the first DTC that pops up is the one to be tackled first.
File Type: pdf
File Type: pdf
File Type: pdf
Cruisin101
Aug 17, 2017 06:30 PM
Dew23
Sep 9, 2013 03:35 PM
ttyR2
Jan 16, 2012 02:21 PM
Randy20g
GX - 1st Gen (2003-2009)
Nov 25, 2010 08:51 AM
MDTim
Apr 21, 2009 10:16 AM
