1999 Lexus ES300 Whine noise coming from engine bay
Old Sep 14, 2019 | 03:59 PM
rajan204's Avatar
rajan204
Default 1999 Lexus ES300 Whine noise coming from engine bay
260,000 Km. After i start the car, the whine is super loud due to high rev as engine is cold. noise gets louder as rpm gets higher, When car is warm, noise isn't very noticeable probably because rpms are low.
Noise comes from right side of engine, near starter and .
Replaced starter. noise still persists. starter relay does disengage. far as all relay tests show
Old Sep 14, 2019 | 06:16 PM
I don't remember hearing a noise like that except when the tensioner bearing (timing belt component) was shot. But it sounds like the noise is transmission side, so not sure what to tell you.
Old Sep 14, 2019 | 06:20 PM
rajan204's Avatar
rajan204
im not so sure what it could be anymore i thought the starter solenoid was bad but it is not so not sure what i should do. as u can see in the vid the accessory belt isn't the best as it sequels a but u can tell that it is not the main noise im referring to.
so do you think its timing belt
Jgarc74
Jul 24, 2019 05:07 PM
allstock
Apr 21, 2014 09:58 AM
wyciwug
RX - 1st Gen (1999-2003)
Apr 16, 2010 02:44 PM
skk440
Sep 21, 2007 11:08 PM
mek88
Maintenance
Aug 26, 2004 09:36 PM
