Reverse indication & others not functioning when put into reverse
Old Aug 8, 2019 | 05:28 PM
JodyH's Avatar
JodyH
Question Reverse indication & others not functioning when put into reverse
I have a 2009 ES350. For a couple of weeks now, when I move the gear shift to reverse:
  1. The transmission DOES shift into reverse gear. The transmission shifts to all gears as expected.
  2. In the "PRNDS" transmission indication in the driver's cluster, the "R" does NOT illuminate.
    1. All other transmission positions indicate as expected when selected. "P" illuminates in park, "D" illuminates in drive, etc.
  3. ​​​​​​​The LCD display on the dash does NOT switch to the rear view camera.
  4. The rear view side mirrors do NOT tilt down.
    1. ​​​​​​​I've verified the mirror selector switch position has no effect on this.
  5. ​​​​​​​The white back up lights do NOT come on.
    1. ​​​​​​​Turn signals and brake lights all DO come on.
I can't identify a fuse that would affect all of these things. Is there a relay that controls all of them? Any other ideas?
Old Aug 8, 2019 | 09:21 PM
nevernu's Avatar
nevernu
all the prob seem to relate to the rear power circuits, i would check the backup light fuse or the park/neutral position switch, cause if that does not work typically the back up camera, and tilt mirrors need that signal to trigger.
eg (b) Reverse-linked
This function tilts the mirror surface downward to improve the visibility when driving in reverse, provided that all the
conditions given below have been met.
􀁺 Engine switch is on (IG).
􀁺 Shift lever is moved to "R".
File Type: pdf
Old Aug 9, 2019 | 05:33 AM
JodyH's Avatar
JodyH
Awesome. Thanks Nevernu, I'll work with that and report back.
-JodyH
Naylun
Mar 19, 2019 11:05 AM
SirBev
Jun 6, 2018 01:27 AM
WendyATX
Apr 3, 2017 06:28 AM
otcviper
Sep 15, 2016 08:55 PM
jerrysayz
Jul 25, 2008 02:29 AM
