Vsc
Orion7,
A doc can know plenty about cars. It seems, way more than you.
I gave the best opinion for your lack of knowledge. As it turns out, it appears that you may have done,if not irreperable, very expensive damage to your car.
If you are asking for help but not liking the answer that you receive, maybe...
Here is a description of that code: https://www.engine-codes.com/p2118_lexus.html
I would check if there are other codes to view. My Inova scanner (#3040) shows one code at a time but the screen shows how many codes are stored.
This dude claims a bad fuse caused his P2118 code on his IS model: https://www.clublexus.com/forums/is-...cked-fuse.html
I was at lexus dealer tday and spoke to service dept. and he spoke to mechanic ,asked if I cleared the code that I got with the scanner ,no I didn't so that's next step anyone have advice on how to do it would be appreciated thanks Alex . In meantime I will try to figure it out .
research says need to reset computer when battery disconnected,may have set code because of tampering with the throttle butterfly,in that case there has to be a reset but not sure how to do it
1Spookey
Oct 25, 2009 05:00 PM
