Draining coolant from the block
Old Mar 26, 2018 | 10:15 AM
acarapella's Avatar
acarapella
Default Draining coolant from the block
Hey all
I want to get coolant out of my radiator, and my block… Was hoping to capture all I drain, so I can reuse it, as it’s relatively new. I need to get below the thermostat housing, which I’m assuming is at the end of the neck that connects to the lower radiator hose. Is there a petcock on the block?
Old Mar 26, 2018 | 11:43 AM
Yes. Look up and past the RH axle you'll see it. There is also one to the right of the oil filter.
Old Mar 26, 2018 | 12:55 PM
acarapella's Avatar
acarapella
Perfect, thanks! That lower radiator hose neck is the thermostat housing right?
99LSprobs
Aug 17, 2018 08:56 AM
Kal333
Jul 23, 2018 07:34 PM
jnesss
Jul 7, 2018 07:34 PM
Elless400
12
May 1, 2017 09:16 PM
ToyotaLexus
RX - 1st Gen (1999-2003)
Dec 13, 2008 11:39 PM
