accessory time
Old Sep 30, 2017 | 12:19 PM
fiddler1's Avatar
fiddler1
Default accessory time
how can i get more "retained accessory time"?
Old Sep 30, 2017 | 03:22 PM
bc6152's Avatar
bc6152
I'd tell you if I had a clue to what it is...
Old Sep 30, 2017 | 05:31 PM
GES's Avatar
GES
Not sure what you mean by retained accessory time, but I will try to guess. Do you mean the time the power stays on ( to radio and power outlets) when you press the stop/start engine button once. It usually stays on for about 20 minutes and then it cuts off to conserve the 12 volt battery. If this is what you mean then I don't think you can extend that time. you just press the stop/start engine button once again.
Old Oct 1, 2017 | 08:39 AM
fiddler1's Avatar
fiddler1
how to get more time (after key off) for radio etc
Old Oct 1, 2017 | 09:29 AM
GES's Avatar
GES
There are other threads that have discussed this. If you want to stop the engine but keep the radio on, here is a solution. Before turning the engine off press the brake pedal firmly, then move the gear shifter to "N" neutral, then turn engine off by pushing the Engine stop/start button once, then move the shifter to "P" park position, then deploy the parking brake, then take you foot off the brake pedal. The radio will stay on for 15-20 minute and the engine will be off.
netcbc
RX - 3rd Gen (2010-2015)
Aug 27, 2015 12:57 PM
m1964
Nov 17, 2012 07:52 PM
jkutti2000
12
Mar 28, 2010 02:34 PM
vlexus
Jun 11, 2008 12:22 AM
cheappc
May 20, 2008 10:05 AM
