Alternator replacement
Old Apr 1, 2017 | 11:33 PM
wsrivers's Avatar
wsrivers
Default Alternator replacement
How difficult is it for a "non mechanic" to change an alternator on a 2ND generation ES300? I recently purchased a brand new battery but today my battery light on the dash came on. After doing some testing it seems that the alternator is no good. I'm ok with that the issue I'm having is whether I can do it myself or should I look for a mechanic to do the swap?
Old Apr 2, 2017 | 04:33 PM
siscolad's Avatar
siscolad
its a simple as ,if you know what your doing, very easy to change the alternator
Old Nov 20, 2024 | 04:42 PM
imtuffynurnot's Avatar
imtuffynurnot
2nd gear
It all depends on what alternator you get. If you go with a lexus alternator, you have to install a conversion kit as the belt is shorter as it is designed to put out more power. If the bolts come off easy, then it is pretty simple. My bolts were literally hydrolyzed on. Very difficult to get off, not a lot of room to work on a GX470 either
Old Nov 21, 2024 | 08:35 AM
bc1_2002's Avatar
bc1_2002
I've had no issues taking the alternator off from my 96 ES300. Also, if you have a multimeter, you can bench test it yourself. Typically, an alternator issue indicates brushes are worn or a diode issue on the rectifier. You can buy a rebuild kit, hopefully from Denso.
The starter can be rebuilt, too.
Try to purchase Denso parts.
Review youtube videos on rebuilding denso alternators.
rakett
GS - 1st Gen (1993-1997)
Aug 21, 2014 04:05 AM
ArmyofOne
Maintenance
Nov 22, 2008 03:15 PM
itgrowsind
Maintenance
Nov 27, 2006 12:17 AM
RUDENESS
Jun 5, 2005 08:48 PM
