ABS code 26 & 26 and interchange questions
Old Jan 19, 2017 | 05:45 AM
Patmark's Avatar
Patmark
Default ABS code 26 & 26 and interchange questions
Lexus newbie, just scored a clean 97 ES300. Over 200k, but seems solid. Brake, ABS, T/C and check engine light always on. Was surprised to learn about bulb monitor system. Rear light out. Fixed, warning still on. Fluid ok, parking brake switch seems to be solid. No obvious wiring issues. CEL is a knock sensor. After looking at intake, I think it's just going to retard my timing for a long while. Awful to get to.
But my big question is the ABS issue. I subscribed to the Alldatadiy. The Lexus manual knocks the bottom out of the GM service version. Several steps outlined for use without Lexus shop equipment. About to spend some time with ohm meter going over some ABS pump and controller suggestions. Code 25 and 26 come up with the paper clip in terminal test. Is this a common code to come across? If so, is there a failure point systemic to this model?
Other big question. If you search car-parts.com with interchangeable parts, it shows that Avalons, Camarys and Soleras with T/C will be ABS pump and controller donors. Could I be this lucky? Spending $50 and an hour at the local U-Wrenchit then bleeding the system sounds like a pretty sweet deal.Shows 97 to 2001 will swap.
Oh, and could the brake warning light be tied into the ABS failure? I've done quite a bit of semi high tech shade tree stuff, but never with a newer Lexus. And 97 is new to me.
Thanking all in advance for reading and suggestions!
Pat
Old Jan 19, 2017 | 10:15 AM
Take a look at this thread
For the ABS actuator here are the potential donors, always match the part number
08/1996-06/2001 TOYOTA CAMRY
08/1996-06/2001 LEXUS ES300
06/1998-11/2002 TOYOTA SOLARA
09/1994-07/1999 TOYOTA AVALON
Old Jan 19, 2017 | 10:40 AM
Patmark's Avatar
Patmark
Default Wow!
This is like over a hundred man-hours invested in troubleshooting. I'm thankful and humble to take advantage of this resource.
And thanks for the quick response. Wouldn't have thought to check alternator output. Will eliminate that first
Boblex
RX - 1st Gen (1999-2003)
12
Feb 9, 2022 07:35 AM
gstreee
May 10, 2014 11:41 PM
mhmh
Oct 26, 2012 01:03 PM
Bobmoorman
Sep 1, 2011 12:22 PM
avrcguy
Jul 10, 2008 11:53 PM
