engine check light on , nothing is wrong
Old May 10, 2003 | 05:46 PM
LEXUS2DIE4's Avatar
LEXUS2DIE4
Default engine check light on , nothing is wrong
nothing visual wrong with the car, good amount of oil, tranny oil, coolant, etc
what are some things to look for?
air filter? plugs? wires?
Old May 10, 2003 | 06:54 PM
Gekko's Avatar
Gekko
I bet it's one/some/all of the following:
1. Oxygen Sensor
2. EGR Valve Modulator
3. Vacuum Switch Valve
Dealer will have a code reader which will tell you for sure. take car in at next oil change and ask for a free read.
Get the work at the TOYOTA dealer, not the Lexus dealer and save yourself some money.
Good luck.
Old May 11, 2003 | 07:32 PM
flipside909's Avatar
flipside909
Lexus Connoisseur
25 Year Member
Default Re: engine check light on , nothing is wrong
Usually when your CEL comes on, it's usually emissions system related. Take it to your local dealer or qualified mechanic to have the codes read.
Old May 15, 2003 | 09:55 AM
bizarreRide's Avatar
bizarreRide
AutoZone will give you a free diagnostic if you check engine light is on. Just takes a minute.
Old May 15, 2003 | 10:12 AM
link13's Avatar
link13
Default gas cap
If you have an old gas cap, start with replacing that. It's only about $8. If the gas cap seal is faulty, that can throw the check engine light as well.
Old May 15, 2003 | 11:53 AM
flipside909
Lexus Connoisseur
25 Year Member
They stopped offering that service here in CA unfortunately.
Old May 16, 2003 | 02:32 PM
badams's Avatar
badams
I just had my check engine light come on, took it to the dealer ($110.00...ouch) they said it was the oxygen sensor, they suggested replacing both for some ridiculous amount, like $700-800 dollars!
I said I'll wait until I need a smog, a week later the light went out...or burnt out.
Any way its off now!
badams
Ps. Where can I get oxygen sensors cheap. Everywhere I called wants $400 or more for both.
Old May 16, 2003 | 10:02 PM
flipside909
Lexus Connoisseur
25 Year Member
It's not a very cost effective item. Try autozone or kragen for the parts if you haven't already done so. Otherwise I'd advise you to try www.toyotaparts4u.com or call up Steve Ganz or Angel at Carson Toyota parts...www.carsontoyota.com.
Old May 21, 2003 | 08:45 AM
LEXUS2DIE4's Avatar
LEXUS2DIE4
found out its my knock sensor, there are two, but only one needs to be replaced.
asked for a toyota dealership about a 93 camry v6 sensor and they said it has a different part number, compared to the es300. is that right? its like 190 canadian here....
also is there another name for the knock sensor ? the guy in the dealership didn't know what i was talking about till he started to type stuff of his computer
Old May 22, 2003 | 12:15 PM
flipside909
Lexus Connoisseur
25 Year Member
It shouldn't be but double check with your local Lexus dealer and another Toyota dealer to confirm the part numbers.
chuckq4yoo
Apr 24, 2018 04:09 PM
rawr2is250
Dec 5, 2013 11:38 PM
Saiji
Oct 2, 2007 09:12 AM
Biaggi
12
Jan 6, 2007 08:03 PM
jcondie
RX - 1st Gen (1999-2003)
Dec 13, 2004 02:09 PM
