Navigation (again)
Old Aug 19, 2016 | 08:50 AM
Lexusguy2k's Avatar
Lexusguy2k
Default Navigation (again)
I was driving a loaner NX while my ES350 was getting a facelift and accessories. I was impressed with the Navigation in the NX. It actually showed in the small screen on the right side of the navigation the upcoming exits, exit number and POI at the exit
I don't think we have this in ES350 2016. I have also noticed my house does not show in myu ES2016 but NX had it. Is there a way to pursue dealer to give at least one free map update? My vehicle is only a week old.
Old Aug 19, 2016 | 09:03 AM
imrankh24's Avatar
imrankh24
The Es also had all the stuff you mentioned. And what do you mean by house? Does it show a small little house?
Old Aug 19, 2016 | 09:10 AM
bc6152's Avatar
bc6152
When I took delivery of my new Lexus, I checked the date of installation on the navigation maps. I found that the maps were over a year old. I asked the SM if I could get an updated version when it was available. He agreed and put it into my service record. I subsequently did get a free updated database. This was about two years ago. I would not pay Lexus for a map update. For long drives I use a $200.00 Garmin portable unit which is updated every 3 months (for free). Like it better than the Lexus system because it has everything including traffic issues.
Old Aug 19, 2016 | 09:35 AM
jollick's Avatar
jollick
The 2015 and up navs are much better regarding traffic than in the 2013 - 2014 Lexus vehicles, IMHO. The newer navs use HD radio for traffic, for free, and will warn of slow traffic on your route and ask if you want to be re-routed. They also show the traffic very much like google maps does on many more streets than the older XM Traffic systems.
Old Aug 19, 2016 | 12:41 PM
Lexusguy2k's Avatar
Lexusguy2k
How do you check when the map was installed/updated?
Old Aug 19, 2016 | 12:54 PM
dchar's Avatar
dchar
I don't think we have this in ES350 2016. I have also noticed my house does not show in my ES2016 but NX had it. Is there a way to pursue dealer to give at least one free map update? My vehicle is only a week old.
You can see the list of exits on the map by changing the Map Mode. Click on Options when you're on the map. You won't see the list until you get on the freeway.
You can also set your Home, I believe you'll need to set it through preset destinations under Options again.
Old Aug 19, 2016 | 06:01 PM
teezee1000's Avatar
teezee1000
within the map, click the options button then click map data.
Old Aug 19, 2016 | 06:37 PM
Zipit555's Avatar
Zipit555
Does the 2015 use HD radio? I assume both the '13 and '14 use XM traffic data subscription?
Old Aug 20, 2016 | 05:00 AM
teezee1000's Avatar
teezee1000
2015's use HD
Old Aug 20, 2016 | 07:23 AM
jollick's Avatar
jollick
Yes, the 2015 used HD radio for the traffic information. Yes, both the '13 and '14 use XM traffic data subscription.
Old Aug 20, 2016 | 12:45 PM
as others have said, you have this in your ES too, all Lexus nav is the same, this feature has been available since at least 2013.
Old Sep 5, 2016 | 09:07 PM
bostonsnow's Avatar
bostonsnow
Default Which has better traffic routing - the new Navs vs phone based apps?
I'm Looking through the various threads on Nav - Given the new Nav system in 2015 and up is better and HD based, how is the traffic based navigation compared to phone based apps like Waze?
In my 2005 I became quite comfortable using Waze on my phone. When buying my 2016, I didn't particularly care that much about getting Nav - it just happened to come with the well equipped cars I was looking at. Just drove today in my 2016 and used waze via bluetooth which worked sort of ok - the waze guidance comes through as though its a phone call coming through, so the first word or two get cut off, but overall worked despite being a bit clumsy.. For navigation, accurate and responsive traffic based guidance is the most important thing to me - would the Lexus Nav be as good? If the Lexus nav is just as good, it would be smoother to use it than the phone. ....
Old Sep 5, 2016 | 09:23 PM
The built in traffic is pretty terrible. Nowhere near as accurate as Waze.
Old Sep 5, 2016 | 09:25 PM
bostonsnow's Avatar
bostonsnow
thanks.
I like the idea that one person posted - Leave your Nav screen set to show the map as you drive (without nav guidance set) , so you can see upcoming streets etc.
Then have Waze running on your phone and listen to the audio directions of Waze
Also - if I put my phone in the further away cup holder, the Waze map is reasonably viewable to me, but of course a bit small.
This is my plan!
Old Sep 5, 2016 | 10:55 PM
dchar's Avatar
dchar
Like mentioned earlier, in-car HD radio traffic data for the navigation isn't very accurate. I've had times where it showed green when it really should've been red because it was completely stopped. Accidents/hazards also don't appear very often.
If you stream music through Bluetooth into your car, you can also use Waze and the info will lower the volume and say the alert. It doesn't go through as a phone call anymore.
giaruso
ES - 7th Gen (2019-2025)
Apr 15, 2024 02:48 AM
fdiphill
May 18, 2019 04:03 PM
cwonglex
NX - 1st Gen (2015-2021)
Jan 10, 2019 07:56 PM
Jcar
Nov 6, 2017 05:09 AM
UCLABryan
26
Aug 8, 2017 08:12 AM
