Over 7.5 is too wide anyways IMO, these cars have 6.5 standard... and the measure is only on the inside of the wheel so the actual width is several inches higher anyway.
Thank you, I'll ask to see if it is.
So if it's over 7.5 it would not fit? And what would be the problem?
Also one more question which offsets would fit? Or does it matter what size rim or the width of the rim?
Thanks!
if you get an 8in with a 45 offset you might need spacers (10mm).
depending on the width you can go with a lower offset. for example, with a 7.5 width you can probably go up to a 25 offset before the tire rubs on the fenders. the wider the wheel, the higher you would need to go on offset. this is just a general explanation, other details and factors may be taken into consideration.
Both of these wheels are inexpensive and very lightweight, good quality wheels. These are Enkei made wheels for about 1/2 the cost. The bolt pattern is identical, you will only need 60.1>64.1mm hubcentric rings which I got online for a few bucks.
The 5 spoke design is my personal favorite but mesh and V spoke wheels also look great on these cars.
