Puddle Lamps
Old Apr 16, 2016 | 12:02 PM
Alkjr's Avatar
Alkjr
Default Puddle Lamps
I just purchased a 2013 ES 350 - Luxury edition, I wonder if the existing side view mirrors are set up for puddle lights? There is a lens under the mirror, is that for puddle light or blind spot monitor? Also, if so would is wired and have a socket for just adding a bulb?
Old Apr 16, 2016 | 01:32 PM
bc6152's Avatar
bc6152
I also have a 2013 Luxury Edition. Your mirrors should have 3 lights. One on the bottom - the puddle lights - One on the side for turn signals, and the blind spot monitor signal (light) is actually inside the mirror. The puddle lights should illuminate when you approach the car with the smart key. There may be a setting for that and I'm not sure.
Old Apr 16, 2016 | 01:35 PM
Alkjr's Avatar
Alkjr
Default puddle lamps
My car is not the ultra-luxury, which puddle lights are standard. I know the blind spot light is on the mirror. Is the lens below the mirror unit the sensor for the blind spot or for a puddle light when installed?
Old Apr 16, 2016 | 01:43 PM
bc6152's Avatar
bc6152
The lens on the bottom is for the puddle light. Don't know where the sensor is for the BSM. I also have a Luxury Edition - not Ultra.
Old Apr 16, 2016 | 02:39 PM
lesz's Avatar
lesz
I don't have my manual handy to check for sure, but, for the puddle lights (which I believe Lexus calls "welcome lights) to turn on when you approach the vehicle, I think you need to have a switch on the center overhead console set in the proper position. You may also need to have the headlights set on "auto", but I'm not sure of that.
Again, if you check the manual, there is a description of what needs to be set to enable them.
Old Apr 17, 2016 | 09:24 AM
kellens's Avatar
kellens
Somewhat unrelated, but you can easily change the light on door which shines down with "Lexus" or custom logo. My dealer offered it free on cars with Ultra Luxury Edition.
Old Apr 18, 2016 | 05:52 AM
jollick's Avatar
jollick
Welcome light illumination control
The side marker, parking, tail and license plate lights automatically turn on at night
when the doors are unlocked using the entry function or wireless remote control if
the light switch is in the “AUTO” position.
There is also a custom setting for the lights but the manual says "Settings that can be changed by your Lexus dealer" which means you need the dealer to do it or use your own OBD programmer like Carista.
Old Apr 24, 2016 | 10:30 AM
Jaythomas's Avatar
Jaythomas
So, if I'm understanding the comments, puddle lights aren't on the premium model. Can they be ordered on a premium?
JB5674
Nov 19, 2013 08:58 PM
bigvain31
Sep 14, 2013 06:22 PM
acdapast
Oct 18, 2012 08:07 AM
midnite c
Lighting
Jan 15, 2007 03:35 PM
Kaius88
Sep 19, 2006 09:54 AM
