Code P1349 - 98 SC400
Old Mar 24, 2015 | 04:39 PM
Mastana's Avatar
Mastana
Default Code P1349 - 98 SC400
Hey guys my 98 sc400 is killing me with numerous amount of problems. Today i was driving and my CEL came on it. I had a friend scan it and it was P1349 i searched it up and i couldnt find anything. If anyone has an idea id appreciate it thanks.
Old Mar 24, 2015 | 09:31 PM
Luxor's Avatar
Luxor
VVT(variable valve timing) System Malfunction. Before you do anything, check to see if your oil control valve connector is plugged in, it should be located near the VVT cam pulley. There is also a chance that a foreign object got caught in your oil control valve and clogged it. If i were you, I'd change the oil and oil filter and then clear the code to see if what ever clogged the oil control valve has removed itself. If the code comes back on, then there is definitely something wrong with the oil control valve or VVT system.
Old Mar 24, 2015 | 09:59 PM
Mastana's Avatar
Mastana
Will do, it has like a Random misfire/rough Idle and i just seen a write up about it and this basically sums it up i will do everything asap. Also if there was a foreign object inside of it would it come out if i did the oil change? Thanks
Old Mar 24, 2015 | 10:19 PM
Luxor's Avatar
Luxor
Your oil filter will catch whatever it was if it freed itself after it caused the check engine light to go off.
Old Mar 26, 2015 | 06:03 PM
Luxor's Avatar
Luxor
Check out this thread I found, it has some good information regarding this code. https://www.clublexus.com/forums/per...ve-filter.html
Old Mar 27, 2015 | 03:45 PM
Mastana's Avatar
Mastana
I just found that one thanks, ill keep this updated on how it goes.
TracyH
May 29, 2019 03:52 PM
TTslim
Aug 27, 2015 04:02 AM
Lexus082
Mar 7, 2013 01:41 PM
cmara2k9
Nov 13, 2011 09:10 AM
ANTW1
Apr 27, 2010 03:20 PM
