2000 ES300 Transmission Problems
Old Jul 13, 2015 | 09:22 AM
autotr8er's Avatar
autotr8er
Default 2000 ES300 Transmission Problems
So here's the skinny. No Transmission response. Engine Starts up, loud whine coming from engine bay, can't pin point it. Noise goes away after engine warms up. If I disconnect the battery (remove negative terminal) and reconnect, I have a fully functional transmission. After some time, 1-5 minutes, no transmission.
Repeat the battery disconnect/reconnect. I have a transmission again. Shifts normally. Fluid is full, color is ok. No evidence of metal flakes. A few minutes later, no transmission. It does this whether I'm driving or sitting in the driveway.
Dealer states needs a new transmission. (surprise) Need your help, folks. I'm open to real solutions. Thanks in advance for your help.
RDS
Old Jul 13, 2015 | 11:34 AM
surgeon0's Avatar
surgeon0
I am not sure of how the toyota ones work yet but did do some things on my honda. Pressure switches and solenoid screens was an easy starting point. If you have torque converter issues then trans replacement is an option to consider.
You will get some better responses soon. All the best.
Old Jul 14, 2015 | 04:38 AM
autotr8er's Avatar
autotr8er
Everything works again once I disconnect and reconnect the battery. Could the whining noise be the transmission pump? Need your help folks. I'll keep the solenoid screens and pressure switches in mind when I pull the pan. Thanks in advance.
RDS
Old Jul 14, 2015 | 09:04 AM
surgeon0's Avatar
surgeon0
Which gear is the whine coming from, 1-2, 2-3, etc? Any slippage? If there is no slip in any yet then some whine is normal. Replacing a pressure switch will prolong the trans. It might be pressure related. Hopefully torque converter is good, whine will be pretty much constant while in that same gear. Change out the fluid to Maxlife or Amsoil.
Old Jul 14, 2015 | 09:40 AM
autotr8er's Avatar
autotr8er
No slippage. Whine is at idle. disappears after warm-up. K, I'll check it all out. So the mystery still is why does it run normal and quit, but I can reset it again, only to quit soon after?
Old Jul 14, 2015 | 09:41 AM
autotr8er's Avatar
autotr8er
Thank you for all the help. I truly appreciate it.
Old Jul 14, 2015 | 03:36 PM
Oro's Avatar
Oro
It sounds like an electrical problem more than anything else; and I don't know these enough to speculate. But a basic questions: is the unit properly filled?
Old Jul 16, 2015 | 10:13 AM
autotr8er's Avatar
autotr8er
Plenty of fluid. i just want to make sure I cover all the possibilities before I start tearing into the transmission.
jamezc88
Jun 27, 2019 05:18 PM
AabirRizvi
Mar 30, 2017 07:32 PM
harryb5a4
Mar 13, 2015 07:04 AM
LivingLege
Feb 14, 2013 08:04 AM
LivingLege
Feb 13, 2013 01:21 PM
