1992 ES300 Oil Level Sensor leak
Old Jun 6, 2015 | 11:43 AM
CoolES200's Avatar
CoolES200
Default 1992 ES300 Oil Level Sensor leak
My oil level sensor connected to the oil pan is leaking around it. It's still working fine, just leaking. You think it's ok to drain the oil, clean around it, and just apply an appropriate epoxy/sealant/liquid gasket?
Thanks for your responses!
Old Jun 6, 2015 | 01:10 PM
PFB's Avatar
PFB
Don't apply anything, I never had to deal with ithis on a Lexus, but I'm sure that there is an "O" ring rubber gasket there. That's what's probaly leaking. You will need to change it.
It could also be the sensor itself, but that's less likely.
Old Jun 6, 2015 | 02:03 PM
I tried to find a part number for the gasket/O-ring but failed the diagram shows the sensor but no part number for the gasket. 90430-27001 might work this is for newer models/sensors.
Old Jun 19, 2023 | 07:26 PM
booboofoo's Avatar
booboofoo
Zombie Thread Alert!
I'm about to tackle this very problem so I'll post photos etc when I'm done.
DLfpv
Jun 25, 2019 11:21 PM
snsrushing
Jul 14, 2010 03:10 AM
nefariousd
Jan 5, 2010 01:33 PM
Brando
Jul 26, 2008 05:12 AM
ckh1272
May 31, 2008 09:53 AM
