Lexus asks for $507.15 to replace CV Boot
Old Nov 19, 2014 | 01:16 PM
johncoby's Avatar
johncoby
Default Lexus asks for $507.15 to replace CV Boot
They said my inner and outer boots need to be replaced. I am clueless on CV Boots.
It is a 2007 ES350 w 75K miles.
$507 seems a bit high, but what do I know? Comments? Suggestions?
Old Nov 19, 2014 | 01:36 PM
LexBob2's Avatar
LexBob2
You might want to get a quote from a Toyota dealership or good independent who works on Lexus/Toyota cars. It will cost you a lot less than at the big L dealership.
Old Nov 19, 2014 | 01:57 PM
johncoby's Avatar
johncoby
Roger that! It is there for a water pump change out. Covered under an extended warranty. The CV boot is not. ****.
Old Nov 19, 2014 | 04:50 PM
xanderES's Avatar
xanderES
Do you have the lexus extended warranty? I had an issue with mine and had it replaced by the extended. They just couldnt bill it by just the boot as they can only sell it by the whole assembly.
Old Nov 20, 2014 | 09:24 AM
igzy's Avatar
igzy
The quote is in the right range. It is priced at 3-4 hours of labor plus parts...
Like others suggested, if you can't do it yourself, you can see a Toyota dealer or independent shop and save a few $$...
Old Nov 20, 2014 | 02:24 PM
johncoby's Avatar
johncoby
Default Warranty covered it! But not the alignment!
The extended warranty covered the repair which requires an alignment to be performed.
For some reason they did not pay for the alignment. WTH?
Old Nov 20, 2014 | 07:06 PM
xanderES's Avatar
xanderES
Seems like you have one of those dealers that is trying to nickel and dime you. Id start going to a different dealership. You shouldnt of even had to argue with the dealership to cover the boot. If the repair needed an alignment to be included it too should be done without fee. WTH is right.
Old Nov 20, 2014 | 11:36 PM
ThumperPup's Avatar
ThumperPup
when i first got my ES350 07
a few weeks latter i found out i needed a new boot passnger front cv was leaking.
the toyota dealership i went to who told me this wanted over a 1000 dollars saying i needed a new half shaft axle i informed them that it was under warranty from lexus.
i went to the lexus dealership showed them the papper work form the toyota dealership.
they got it covered under lexus warranty parts and labor for the whole job came to 590 i think.
Old Nov 21, 2014 | 08:22 AM
johncoby's Avatar
johncoby
Default Is the alignment necessary after CV boot replacement?
I've contacted the warranty company to ask why the alignment was not covered since Lexus said it was "necessary". I would think it was necessary since the axle was removed.
I've got a complaint with the warranty company filed. Lets see what happened.
Old Dec 18, 2014 | 01:58 PM
retired's Avatar
retired
Default quick inexpensive fix for slinging grease if ends are leaking
This problem has been address in the LX 470 forum and it works if the the CV boot is only slinging grease from the ends. Will not work if the CV axle is making noises and/or the rubber boot is ripped....Here goes, A special TOOL can be purchased for about $25 to tightened the existing clamps OR (the method I used) stainless steel radiator hose clamps can be placed over the existing clamp and tightened.. Take care to NOT cut into the rubber boot. These clamps can be bought at the local parts store. The size I used was 1" to 1 3/4"...Having the car on a lift makes it easy to assess. . Four clamps are needed to do both cv axles. Hope this helps
Poppa
Jan 10, 2018 05:04 PM
JASP615
GX - 1st Gen (2003-2009)
Dec 7, 2012 08:42 AM
gb403
Apr 6, 2012 10:30 AM
GGGXXX
Aug 4, 2008 03:41 PM
