Spark Plugs
Old Dec 14, 2014 | 11:04 AM
Crujal's Avatar
Crujal
Default Spark Plugs
I have ES 350 with 118000 miles. And for the last 6 months I've noticed my car become louder and louder. And now it's beginning to shake and vibrate a little. The Check engine light and check VSC light came on then it went off. I can also tell it doesn't have the same pick up when I hit the gas. So is it time to for new plugs and coils? Please help
Old Dec 14, 2014 | 12:12 PM
GCL's Avatar
GCL
You need to check the codes (Autozone nearby?) The codes should still be stored in history.
The codes will reveal a lot and will save you time trying to guess what is wrong (or replacing the wrong parts). If you still need help, post the codes.
Old Dec 14, 2014 | 04:42 PM
ESh's Avatar
ESh
Are they original plugs? If yes then 118000 is just too much.
Old Dec 15, 2014 | 08:44 AM
igzy's Avatar
igzy
The maintenance schedule recommends spark plug replacement at 120,000 miles...
Old Dec 16, 2014 | 03:54 PM
jimmy2x's Avatar
jimmy2x
Made me chuckle! I can easily recall doing my own tune-ups every 15,000 miles with new plugs and points and setting the timing. My 2010 has about 50,000 miles and has not had one issue - oil changes only. Truly a masterpiece of modern engineering.
Old Dec 17, 2014 | 04:55 AM
igzy's Avatar
igzy
Hehe, yes. I used to have one of these in my toolbox:
I barely use most the tools I have nowadays. The quality and reliability has improved significantly since the days I owned my first cars...
Old Dec 19, 2014 | 10:51 AM
Lexample's Avatar
Lexample
My car did the same thing at 90,000 miles. I had my codes pulled at Jiffy Lube. For me, it's a new coil and plug and cylinder 2.
Masters101
Sep 13, 2014 07:27 PM
Byprodrive
May 6, 2013 11:42 AM
emadrigal
Mar 3, 2013 03:38 PM
nicks88
13
Sep 14, 2012 01:27 PM
GLIDESUL
Jul 10, 2010 09:17 AM
