Best Projectors??
Old Oct 28, 2014 | 06:53 PM
funcrusher's Avatar
funcrusher
Default Best Projectors??
I'm going to use projectors on my 2000 ES before I install a HID kit. What's the best to go with? Is there a popular one among Lexus owners?Thanks guys
Old Oct 29, 2014 | 04:53 AM
ZeusES300's Avatar
ZeusES300
Morimoto Mini H1, it's the easiest to retrofit with minor modifications.
Old Oct 29, 2014 | 09:55 AM
funcrusher's Avatar
funcrusher
Thanks brother it seems like that's the go to projector kit after messing around online. What about the Mini D2S?
Old Oct 29, 2014 | 11:05 AM
funcrusher's Avatar
funcrusher
I was talking to Retrofit Source earlier and he recommended the FX-Rs
www.theretrofitsource.com/complete-retrofit-kits/bi-xenon-fx-r-stage-iii-kit.html#reviews
Old Oct 29, 2014 | 11:49 PM
ZeusES300's Avatar
ZeusES300
The FX-R is nice but it involves a bit more modification then the Mini H1. The Mini H1 has a good size and fits real nice inside the housing along with the shroud. Now the Mini D2S is bigger and will not fit into the housing " I already tested that myself". If you new to this i would recommend the Mini H1 its very easy to install. Check out the videos on theretrofitsource of installations.
Old Oct 30, 2014 | 04:28 AM
funcrusher's Avatar
funcrusher
Honestly I will have it all done at a shop. I dont have the time to be working on it. Im confused on which bulbs, shrouds and halos to choose
Old Oct 30, 2014 | 11:00 AM
ZeusES300's Avatar
ZeusES300
The FX-R uses D2S bulbs and the Mini H1 uses H1 bulbs shrouds vary and when choosing a shroud it shows you a option XB LED Halo's to choose from.
Old Oct 30, 2014 | 12:09 PM
funcrusher's Avatar
funcrusher
Would you go with the FX R if someone else was doing the work?
Old Oct 30, 2014 | 12:55 PM
ZeusES300's Avatar
ZeusES300
Definitely.
Old Oct 30, 2014 | 01:42 PM
funcrusher's Avatar
funcrusher
Ok but I'm still confused on what bulbs to choose from. I am putting a 4300K Phillips kit for my lows with this projector so should I just go with the 4300k option when ordering? Or one of the Phillips or Phillips Extreme Visions? I don't kbow what the hell all the different ones are or really mean.
Same with Shroud and Halos.
funcrusher
Lighting
Feb 10, 2015 01:30 AM
Muti007
GX - 1st Gen (2003-2009)
23
Mar 22, 2012 03:39 PM
1kvolts
Lighting
Oct 11, 2007 11:44 AM
Slinger
Lighting
20
Feb 13, 2007 02:52 PM
Boosted
Lighting
Apr 20, 2004 04:11 PM
